2000 tj a.c. question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2000 tj a.c. question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-20-2015, 06:26 PM   #1
jeeper95creeper
Wife's 2000 tj with 2.5 sometimes cuts off when she turns on the ac.does anyone know why that happens?
jeeper95creeper is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 02:41 AM   #2
dos0711
Compressor could be starting to seize up. Have you added Freon lately? Might be overfilled...
2000 Wrangler TJ, 4.0 6 cyl, A/T, G2 Dana 44s, ARB Lockers, 4.10 ratio
dos0711 is online now   Reply With Quote Quick reply to this message
Unread 08-21-2015, 04:23 AM   #3
jeeper95creeper
Yes I've added some but it was doing that before I added any
Unread 08-21-2015, 05:13 AM   #4
TheBoogieman
Pure Evil Jeep Freak!
TheBoogieman's Avatar
At idle or when driving?
If you can tolerate the Bilsteins, that will invalidate any discussion you and I may have from now on.They are quite possibly the most annoying damper I've ever used.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 06:38 AM   #5
JWebber
Cuts off as in engine dying? if so that's a FUBR compressor. Or you talking about the compressor cycling?
JWebber is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 06:45 AM   #6
JBTJ
It would be kind of hard to add Freon when they haven't even made it since the 90's. Just so you know.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 07:56 AM   #7
Jeepsr4me
Could be the idle up circuit wire is not plugged in.
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 08-21-2015, 10:13 AM   #8
jeeper95creeper
Engine dies while driving and idling.
Unread 08-21-2015, 11:47 AM   #9
JWebber
if the engine dying when the compressor kicks on then the compressor is toast.
Unread 08-21-2015, 12:04 PM   #10
jeeper95creeper
It doesn't do it every time.just sometimes
Unread 08-21-2015, 01:38 PM   #11
dos0711
One in every crowd...
Unread 08-21-2015, 04:19 PM   #12
JBTJ
Well you were the one to say freon.
