2000 TJ AC Condenser - removal - JeepForum.com
post #1 of 11 Old 09-13-2007, 09:49 PM Thread Starter
00YellowSub
So I have been working on getting my AC running for the past couple of weeks (In between work and the baby). I replaced the compressor, drier and low pressure line (Orfice tube as well). When I got the system pressurized the compressor got the system up to 450 - 500 psi. (No leaks, that's good) That's one hell of a compressor, but definitely too high for an AC system. Talking to the AC guy that hooked me up, we decided it was my condenser that was causing the pressure issue and it needed to be tested / replaced. Not a problem, I can do that.
I bought the new condenser, and proceeded to remove the old one only to find that it is held in by 4 bolts with some weird rubber and metal nut on the other end. Looks like some type of nut covered in rubber.
Has anyone had any experience with this, how do I get the bolts out so I can install the new condenser and get this AC running for my little boy. (It's hot in So. Fla.)
Any help would be appreciated.
00YellowSub is offline
post #2 of 11 Old 09-13-2007, 09:54 PM
hemmer
i cant help ya here cause i havent even looked at my jeeps condenser and its dark out. but just wondering what refridgerant did you choose to use?
hemmer is offline
post #3 of 11 Old 09-13-2007, 09:58 PM Thread Starter
00YellowSub
Refridgerant
R134 - Whatever the AC guy uses, comes in a light green canister.
post #4 of 11 Old 09-13-2007, 10:01 PM
hemmer
alright ya thats the new stuff thats not harmful to the ozone. i was just wondering cause a lot of people are puttin the r12 back in these days if they can find it.
hemmer is offline
post #5 of 11 Old 09-13-2007, 11:43 PM
Rocky529
Rocky529's Avatar
You have to remove the radiator, evacuate the a/c system, and then you can unbolt the condenser.
Don't add R12 to a R-134a system.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #6 of 11 Old 09-14-2007, 12:32 AM Thread Starter
00YellowSub
Removal
The AC has been discharged for a while, I replaced the Compressor, Drier and Lower Pressure line.
I removed the radiator, but the bolts on the condenser will not unscrew. They turn and turn, and turn,.. they have a rubber feel when they turn. If you look through the grill you will see just that, rubber.
post #7 of 11 Old 07-08-2013, 05:40 PM
helzerr
Sorry to revive such an old thread, but has anyone figured this out?
I'm now facing the same exact issue - the topmost two condenser mounting bolts just "spin" while rotating the rubber mounts they're bolted into. If I had an air-powered impact tool, I might be able to blast them out, but I only have hand tools available here...
helzerr is offline
post #8 of 11 Old 07-08-2013, 06:30 PM
J03_TJ
Mine were a major pain. Had to grip them from below through the grill holes with needle noses and channel locks on the rubber side. They were tough to get apart for sure. The rubber nut end was barely identifiable when I finally twisted the bolts out of them from grabbing with the pliers. Good luck.
J03_TJ is offline
post #9 of 11 Old 07-08-2013, 07:46 PM
helzerr
Yeah I finally got mine out, but destroyed the rubber in the process. Does anyone have a part number for replacements? I've looked on some of the part diagrams, but this part is not shown :-/
*EDIT* I believe they're J4003120, also Home Depot: http://www.homedepot.com/p/1-4-in-20...3998/202210206
helzerr is offline
post #10 of 11 Old 07-08-2013, 11:21 PM
J03_TJ
Ace hardware had two types, I ended up going with the ones that had a rubber flange, looked like a fat "T" if that makes sense. The rubber OD is smaller than the mounting holes so you can pre-thread them onto the screws and pop into place. I might be off on that though, just how I imagined they would have gone in before tightening.
J03_TJ is offline
post #11 of 11 Old 07-10-2013, 05:53 AM
wesboy
I used these on my 97 -
https://www.clipsandfasteners.com/Pr...ode=PAS1095-25
1/4"-20 for 1/2" hole
- they were perfect.
97 TJ Sport 4.0L Auto RHD
wesboy is offline
Help ID this AC condenser! Jay98TJ TJ Wrangler Technical Forum 5 09-04-2009 02:55 PM
Removal of Oil Pan from 2000 TJ 4.0L auto fleck TJ Wrangler Technical Forum 4 08-11-2009 11:00 AM
a/c condenser slowsupratt TJ Wrangler Technical Forum 1 07-31-2007 07:59 PM
2000 4.0 head removal? lennyg TJ Wrangler Technical Forum 18 06-20-2005 06:37 PM
Ac Condenser nuts captain_andrew TJ Wrangler Technical Forum 3 08-21-2004 10:20 PM
