2000 Sahara TJ - Center Console Bolts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2000 Sahara TJ - Center Console Bolts
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 09-24-2014, 06:27 PM   #1
JulioMedina
I have crawled a bunch of threads with no goo answer. I called a local dealership today and they said when they look it up it says not serviced so they could not tell me size or any helpful information. I need to bolt down my center console it has none of the screws/bolts in and its not sturdy. Can anyone tell me the sizes I will need and where a good place to get replacements would be.
JulioMedina is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 07:01 PM   #2
wwch99tj
I'd no one answers I can pull one of mine tomorrow evening...
Check the pull out bins at Lowe's, I do know they have a 10 mm head and are about 3/4" long
Sent from my Galaxy Note 2 using my thumb
wwch99tj is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 08:11 PM   #3
nickkick
Do you mean the screw size indicated as 4 in the diagram?
They are hex flange head M6.3 x 1.8 x 25.4.
nickkick is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 08:50 PM   #4
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Is the bolt size for this really crucial?
Unless I'm missing something, seems like you could use practically anything.
Wheelin98TJ is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 09:07 PM   #5
nickkick
Yup. I would at least get the same threading though. Maybe some washers if needed.
Unread 09-25-2014, 04:43 PM   #6
JulioMedina
Yep it's #4 in that diagram above. I would not be opposed to using something that fits even if it was not OEM. I'm not very savvy so I don't know where to begin as far as size goes.
Can anyone tell me what I could look for that fits the above dimensions?
Unread 09-25-2014, 06:05 PM   #7
wwch99tj
Lowe's sells flange head bolts possible the closest would be 1/4-20
Unread 09-26-2014, 02:20 AM   #8
Jonny Jeep
Jonny Jeep's Avatar
A 1.8mm thread pitch would be 14 threads per inch. Being coarser than UNC you may be able to find 1/4" self tapping screws with that sort of thread pitch.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it."
Adam Cooper (19th century)
Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm
Online factory service manuals (FSMs) and parts lists can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm
If the link doesn't work properly, look for the service manual link under Jeep Resources at the bottom of the page.
Jonny Jeep is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 07:17 AM   #9
wwch99tj
The brackets aren't very thick
re-threading would be easily done
Unread 09-26-2014, 07:28 AM   #10
aagill225
I always keep any loose or leftover nuts and bolts. If you have any friends or are close with your mechanic I'd bet they may have the same bucket of nuts-n-bolts laying around. Any hardware store would have a wide variety of the stuff. They may be the same size that hold the dash bezel in place. Take one of those out and see if it works. Although, if you lost the OE bolts chances are the bolt hole has widened. You may need a size bigger.
'99 WJ, 4.7L, completely bone stock, except for 245/65/16 tires
'76 Jeep Grand Waggy, 360cid Edle 660cfm/edle intake Quadratrac
'02 Exterra 3.3L, 5-spd, traded YJ for it :(
'89 YJ 2.5L, 5-spd, Borla header, dynomax super turbo muffler, Big-O XT 30x9.5r15
2004 Jeep Liberty Renagade 3.8L 2wd
'86 XJ 2.8L V6, 5-spd manual tranny (My 1st)
aagill225 is offline   Reply With Quote Quick reply to this message
Unread 09-26-2014, 03:10 PM   #11
Jonny Jeep
Jonny Jeep's Avatar
Had a look at the acme screws (10mm hex head) and sheet metal screws (#3 posi drive) in work today. The size 14 screw thread is 1/4" in diameter and 14 tpi, which is as close to M6.3 x 1.8 as you'll get.
center console , jeep wrangler
