-2000+ rpm idle problem - Page 2 - JeepForum.com
post #16 of 19 Old 12-29-2013, 06:30 PM
TJSIDNEY
Originally Posted by jeeper01ca View Post
Just ordered a camshaft sensor and it will arrive tomorrow, if I get lucky to do it in this cold, I will report back and I'll try to have a write-up.
Does it still idle high now that you changed the camshaft sensor?
Have you ever had someone say “I read online that….” Really? You read it online so that makes it true? Sometimes yes, but where did you get your information?
TJSIDNEY is offline
post #17 of 19 Old 12-29-2013, 07:30 PM
jpin86
My 2003 TJ has been doing the same thing occasionally lately. My high idle is 1200 rpm. When I shut it off, it goes back to normal. I have a throttle position sensor code.
jpin86 is offline
post #18 of 19 Old 12-29-2013, 07:41 PM
Jam1965
I had the same problem, bought a auto zone IAC, worked for about 6 months then the same thing. High idle, shut it off then it would idle fine. I finally bought a factory IAC, problem solved.
Jam1965 is offline
post #19 of 19 Old 12-30-2013, 05:26 AM
TJSIDNEY
Same here... but I also changed the tps ... go mopar .. autozone doesnt get more ch business from me anymore.. napa or dealership for parts... sad but true..
TJSIDNEY is offline
rough idle
