2000 4.0l tj gauges not working - JeepForum.com
post #1 of 6 Old 08-30-2011, 08:24 PM Thread Starter
Aaron0028
Last night I went out to get an engine code from my tj, I did this by pressing in the odometer button then turning the key to on (not start) then off then on then off then on and the gauges lit up and started to move. The rpms went to 1k then 2k ect all the way to 6k all the other gauges did the same and in the odo window it read 1111111 2222222 all the way to 999999. When I went out this mourning to move it none of the gauges worked! Anyone else have this happen to them? I'm hoping for a quick simple fix, thanks
Aaron0028 is offline
post #2 of 6 Old 08-30-2011, 09:39 PM
navy4life
Take the gauges out and bend all the prongs on the back a little bit to give them a better connection. TJ's had a problem with this, the TJ I just sold had the same thing happen.
navy4life is offline
post #3 of 6 Old 08-30-2011, 10:01 PM Thread Starter
Aaron0028
anyone know how to just reset them, if their even is a way without having to take anything out???
post #4 of 6 Old 08-31-2011, 02:06 AM
Jonny Jeep
Jonny Jeep's Avatar
You can't get engine codes from 98-00 model years. By pressing the odometer button you put the cluster into the actuator test.
Cluster not coming on could be caused by a blown fuse as well as a problem with the cluster connectors. I can't tell you which fuses to check as i'm on my mobile. Check the wiring diagrams in the FSMs linked in my sig.
Edit: Back home now. Your cluster gets constant power from fuse 25 in the underhood PDC, and switched power from fuse 10 behind the glove box. Check them first as it's the simplest and cheapest thing to do.
Jonny Jeep is offline
post #5 of 6 Old 08-31-2011, 08:08 PM Thread Starter
Aaron0028
seems like the gauges should still work cause whenever i do the test where all the gauges move they still work??? but when driving they dont?
post #6 of 6 Old 09-01-2011, 12:45 PM
Jonny Jeep
Jonny Jeep's Avatar
The cluster test is just to check that all gauges and cluster controlled lamps are operative. When driving the PCM tells the cluster over the data link connector what position each of the gauges should be in. It's possible you have a bad connection at the data pin at the rear of the cluster. If you search there are threads on the forum about cleaning up the cluster connectors.
4.0 , gauges , lift , tj , wrangler
2000 tj 4.0 gauges not working Aaron0028 TJ Wrangler Technical Forum 0 08-30-2011 08:03 PM
Gauges mot working. mgfi26 YJ Wrangler Technical Forum 6 05-19-2011 07:16 PM
gauges not working, help! mclovinal TJ Wrangler Technical Forum 5 10-19-2010 11:05 PM
some gauges not working jkm211 YJ Wrangler Technical Forum 3 01-04-2009 06:12 PM
gauges not working right. tbm81 YJ Wrangler Technical Forum 4 03-18-2001 09:16 PM
