2000 4.0 TJ coolent leaking-what to check before buying a water pump? - JeepForum.com
post #1 of 5 Old 03-05-2009, 03:12 PM Thread Starter
dequity
Just got this jeep the other day. Noticed that after driving a few miles I get about a cupor so of coolent on the ground. The coolent comes from the engine so I've ruled out the radiator. I'm guessing it's a water pump.
Questions:
1. Where else should i check before ripping out the water pump.
2. How in the heck do I change a water pump on this truck?
3. Best palce to purchase said water pump.
Thanks
00 TJ 4.0 / 98 5.9 Liter Grand / 98 C5 Corvette (set up for SCCA racing)
dequity is offline
post #2 of 5 Old 03-05-2009, 03:45 PM Thread Starter
dequity
ttt this place stays busy.
dequity is offline
post #3 of 5 Old 03-05-2009, 04:48 PM
mcg311TJ
Questions:
Thanks
Did you find out were it's leaking from?
If it is the WP just go get a new one @ AZ or discount or any auto parts store. They are very easy to replace with just simple tools.
Or you can go my route and get a high flow WP. ie flowcooler brand. And your replacing the WP also change the thermostat why your at it. It sits behind the WP.
mcg311TJ is offline
post #4 of 5 Old 03-05-2009, 04:57 PM Thread Starter
dequity
Good advice. If it turns out to be the wp I'll change teh thermostat at teh same time.
dequity is offline
post #5 of 5 Old 03-05-2009, 06:02 PM
TJW909
Buy an oem pump. You will be money ahead and will only do the job once.
TJW909 is offline
Replaced water pump....still leaking coolant. HELP PLEASE Imped TJ Wrangler Technical Forum 19 10-29-2012 10:28 PM
My 00 TJ is leaking coolant badly? Water pump? ImThatGuy83 TJ Wrangler Technical Forum 3 08-11-2009 06:53 PM
Water pump leaking after replacement REckman TJ Wrangler Technical Forum 1 02-16-2009 09:41 PM
Water pump leaking? Help!!! SoTX Hunter TJ Wrangler Technical Forum 23 09-21-2006 02:42 PM
need help!! coolent leaking BAD! water pump? drew76924 TJ Wrangler Technical Forum 4 03-15-2006 06:14 AM
