2" Suspension Lift Modifications? - JeepForum.com
post #1 of 8 Old 09-10-2004, 08:19 AM Thread Starter
mossimo19
I was just talking to one of my friends about my lift. I've had a 2" suspension lift for about five years now. I only had to change the coils with longer ones, change shocks & disconnects, and steering stabilizers but do I need to do anything with my drive shaft since it's on an angle? Was there anything else that I needed to do because my Jeep has been running funny. It's making some grinding noises from the rear passenger side (at least that's where is sounds like it's coming from). It originally made a weird grinding noise in the front when I was in 2nd gear and it would not move since then I haven't heard it from the front but now it comes from the back once in a while. Was there anything else that I was supposed to do ro should still do? Any ideas where the noise is coming from? I also hear some knocking noises when I hit bumps and stuff, sounds like something is loose but can't figure it out. Any help would be great...thanks!!!
97 Moss Green TJ
GO WINGS!!!
mossimo19 is offline
post #2 of 8 Old 09-10-2004, 10:03 AM
Brassmonkey
2014 KL Cherokee
For the sound when you hit bumps, check the shocks in the back. The bolts going into the bar pin might not be tight enough.
Brassmonkey is offline
post #3 of 8 Old 09-10-2004, 12:33 PM
ChristopherJ
Resident Physician
ChristopherJ's Avatar
2017 JK Wrangler
Your sig says you have a '97 YJ?
ChristopherJ is offline
post #4 of 8 Old 09-10-2004, 02:05 PM Thread Starter
mossimo19
Sorry...mental mistake...I fixed it...
97 Moss Green TJ
GO WINGS!!!
post #5 of 8 Old 06-20-2013, 09:15 PM
commodude90
I know, huge time difference between post dates, but i had this problem just last month. So for anyone who lands he lre with the above problem, this is what I found. A year after putting on my 2.5 inch lift, when putting the jeep into gear, I would get a grind, and it would feel like the rear was binding up on one side enough to lower the rear corner of the jeep. I could feel it when in the drivers seat, but did not see movement when I watched someone else do it from the outside.Ii checked everything from the shocks, to universals. It turned out to be loose shackles. It also caused a rattle when driving down brick streets. I found it when I had jacked up the rear axle and saw about a 1/8" gap between the bottom of the leaf springs and the axle. After tighitening up all the shackle's all the way around, thies took care of my mysterious thunk when putting the jeep into drive and the rattle when going over bumps. I now check all my suspension component every time I'm under it, after offroading or whenever somethings doesn't feel quite right. My lift kit came with wedges to tilt the axle the proper amount for the driveshaft to keep a better angle from the rear differential to the transfer case.
commodude90 is offline
post #6 of 8 Old 06-20-2013, 09:19 PM
rchase559
Reviving a nearly 9 year old thread to talk about loose shackles (and by the description in your post it sounds like you tighten the u-bolts)? TJs don't even have leafs...
rchase559 is online now
post #7 of 8 Old 06-21-2013, 06:08 AM
lloydsmale
2015 JK Wrangler
if you have nothing good to say-----
2015willys 4 cyl tj 2017 silverado yamaha grizzly, Polaris rzr 04 z06 vette, 600/800 crossfire cat
lloydsmale is offline
post #8 of 8 Old 06-21-2013, 10:54 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Let the dead rest.
TheBoogieman is offline
modifications i will have to make after putting in a 2.5" suspension lift wrangler10 TJ Wrangler Technical Forum 28 10-19-2009 06:11 PM
2" OME suspension lift w/ shocks & Springs. Not theBB or the2.5" lift CCJ TJ Wrangler Technical Forum 46 08-27-2009 01:44 AM
98 tj wrangler (4" suspension lift + 3" body lift) jeepster069 TJ Wrangler Technical Forum 5 05-03-2009 04:28 PM
1" or 2" Spring Spacer with 4" Suspension Lift on 2000 TJ iBkickinit TJ Wrangler Technical Forum 12 03-20-2006 08:25 AM
