2 stupid questions - JeepForum.com
post #1 of 9 Old 06-23-2007, 10:23 AM Thread Starter
dcfeeiv
2 stupid questions
numero uno
when the jeeps in 2wd its rear wheel driven right?
numero dos
im replacing my radiator im thinking about the 2 row all metal variant or 3 row all metal to put in. i rememeber you guys saying to go w/ an aluminum radiator(yes i know that aluminum is metal) is this the thing you were thinking of? http://www.radiatorbarn.com/s7.asp?a...L+ENGINE+SIZES
dcfeeiv is offline
post #2 of 9 Old 06-23-2007, 10:25 AM
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
i can answer the numero uno question, yes it is
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline
post #3 of 9 Old 06-23-2007, 10:28 AM
Crashnburn80
Crashnburn80's Avatar
1. Yes.
2. Those are 'all metal' meaning no plastic parts. The do not say aluminum, so they are likely steel.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #4 of 9 Old 06-23-2007, 10:32 AM Thread Starter
dcfeeiv
but steel is better than plastic right?
so the order is aluminum is better than steel which is better than plastic right?
dcfeeiv is offline
post #5 of 9 Old 06-23-2007, 04:56 PM
LightningRod
I have that radiator and its way better than the stupid stock plastic one. All you need is the two row radiator.
LightningRod is offline
post #6 of 9 Old 06-23-2007, 05:16 PM
4wheel4real
4wheel4real's Avatar
x2 on raidiator barn all metal 3row radiator. I replaced mine and I have not had any problems.
98 White TJ
4.0l Automatic Transmission.
3.5" Rubicon Express Lift, 33x10.5 Bfg Mud Terrains on 15x8 Crager Black Soft 8's.
4wheel4real is offline
post #7 of 9 Old 06-23-2007, 09:13 PM Thread Starter
dcfeeiv
will i notice a difference between the 2 row and 3 row?
dcfeeiv is offline
post #8 of 9 Old 06-24-2007, 08:50 AM Thread Starter
dcfeeiv
anyone able to help? (i just wanted to say bump but the forum wouldnt let me)
dcfeeiv is offline
post #9 of 9 Old 06-24-2007, 09:07 AM
Stu Olson
Stu Olson's Avatar
There has been a fair amount of discussion in regards to two row and three row radiators and if the three row provides better cooling.
A three row has more metal in the core and so some say the air flow through it is reduced. This reduced air flow then provides decreased cooling performance.
Some with the three row say they work just fine.....and I won't argue that fact assuming they live in a climate where they are not pushing the envelope of the cooling system during the hot summer months.
Others say that in order to reap the benefits of what the three row offers, you need to replace the stock fan clutch and fan with the heavy duty fan clutch and a 7 blade fan. This provides for more air flow and brings the cooling performance back.
A friend of mine, who lives in Tucson, AZ (which also gets quite hot in the summer) installed a 3 row and had poor cooling performance (he did not install the HD clutch and new fan). He removed the 3 row and installed a two row.....leaving everything else as it was. No cooling issues from that point on.
A good aluminum radiator runs about $500 (sometimes more) and often times requires you to do a little fab work to get it mounted properly (not always....depends on the manufacturer). A friend of mine has one and has reported no improvement in his cooling performance.
I have a two row all metal replacement radiator in my TJ and it seems to do as well as the factory unit that it replaced.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
2 stupid questions LuigiROX JK Wrangler Technical Forum 16 01-04-2009 12:09 PM
two stupid questions Sh4dowRac3r TJ Wrangler Technical Forum 12 09-24-2007 05:39 PM
stupid questions...please help! ea615sc TJ Wrangler Technical Forum 3 06-05-2006 05:45 PM
Few stupid questions from a newb Lex05slvr TJ Wrangler Technical Forum 18 07-20-2005 10:01 PM
A few basic stupid questions... Alheim YJ Wrangler Technical Forum 5 04-12-2002 12:01 AM
