Quantcast 2" Spacer Lift -Coil Spring Rattle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2" Spacer Lift -Coil Spring Rattle
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 06-25-2008, 06:53 PM   #1
Ralmoor
I installed a 2" inch spacer lift the other week and I noticed that I had a rattle. I could not figure out where the rattle was coming from so I did some research on the forum. I got a mallet and starting hitting my skid plate, cat, exhaust and I heard the noise up front. It appears to be my front coil spring. All the other springs sound solid but that one. It rattles when I hit it with the mallet. I imagine it is just sitting on the spacer and bottom mount wrong. It appears to be seated properly. Could it be the spring is bad?
Ralmoor is offline   Reply With Quote
Old 06-25-2008, 06:55 PM   #2
thejafe
Can you post a pic? Make sure that the pigtail at the bottom of the coil is sitting in the little notch on your axle.
Visit My Homepage!
thejafe is offline   Reply With Quote
Old 06-25-2008, 07:06 PM   #3
BLATMAN
Thats Weird, Sure Its Not Cracked Anywhere? If Its Seated Properly It Shouldnt Rattle. Did U Put New Shocks On? If So Were They All The Correct Size?
[FONT="Impact"][COLOR="Green"]02' TJ I6[/COLOR][/FONT][COLOR="Silver"]4in. R.C. lift[/COLOR]
adjustable R.C. Trac bar
[COLOR="Silver"]R.C. steering stabilizer[/COLOR]
33x12.5 General AT Grabbers
[B][COLOR="Black"]Pro Comp black steelies[/COLOR][/B]
[COLOR="DarkGreen"][B][__][/B]
OlllllO[/COLOR][COLOR="DarkRed"][QUOTE]I think you should put a CAI, Headers, new muffler.. some high flow cats... maybe one of those trail jammer chips.. oh and a tb spacer... can't forget that. You will be passing prius' in no time, unless their accel pedal is stuck..[/QUOTE][/COLOR]
BLATMAN is offline   Reply With Quote
Old 06-25-2008, 07:44 PM   #4
Ralmoor
I will have to take a pic. I did not install new shocks and i did look to see how it was seated and it looked fine. I do remember putting the pigtail in the notch but maybe it moved. I did not see any cracks on the spring.
Old 06-25-2008, 08:07 PM   #5
BLATMAN
Regardless. U Should Get Some Bigger Shocks Along W The Spacer Lift. It Will Allow For More Travel When Ur Wheelin. More Flex The Better
Old 06-25-2008, 08:32 PM   #6
Ralmoor
Yeah. I will swing by the shock shop on the way back from getting my divorce papers....
Old 06-25-2008, 08:44 PM   #7
thejafe
He's right about new shocks. If you plan to wheel your rig and disco. your swaybar you will need longer shocks to compensate for the extra 2" spacer that is now there.
Visit My Homepage!
Old 06-25-2008, 10:07 PM   #8
mdawg4x4
If you took the shocks loose, did you get them tight enough after reinstalling them.
98 TJ Sport: 2" Skyjacker spacers w/Rubicon coils, Rancho RSX shocks, 33-12.50 BFG MT on 15X8 Mickey Thompson Classic Locks, Borla header, Flowmaster Mufler, Pioneer sound W/12" RF P3 sub and MTX amp
06 Nissan Frontier NISMO CC 4X4: 2.5" lift with Rancho RS9000X shocks, 285/75-16 BFG ATs, Alpine sound
Mdawg's 98TJ @ Cardomain, http://www.mississippi-mud.com/forums/index.php?
mdawg4x4 is offline   Reply With Quote
Old 06-26-2008, 04:44 PM   #9
Ralmoor
I plan on checking that everything is tight tomorrow. I did plan on getting new shocks next year and I agree with the 2" inch spacer lift they are needed but I have already exceeded my jeep budget for this year.
Glock Forum
