2" SL with 3/4" BB and Sway bar links? - JeepForum.com
post #1 of 6 Old 07-02-2013, 04:54 AM Thread Starter
mnm99
If I did the BDS 2" SL and wanted to add 3/4" spacers in the front to level it out, will I have to replace the sway bar links too since I'm going higher than 2"?
mnm99 is offline
post #2 of 6 Old 07-02-2013, 05:34 AM
SlackJaw
baby jeep
SlackJaw's Avatar
You have 2" links already, then no. You still on stock links? Then it might be worth consideration, but you're still probably okay unless you plan on catching some big air from time to time
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #3 of 6 Old 07-02-2013, 05:43 AM Thread Starter
mnm99
Stock links. No plans of big air, but like to do things right. If I really don't need them that would be great.
mnm99 is offline
post #4 of 6 Old 07-02-2013, 05:49 AM
joe_jeep
you could get away with stockers till u break one. after that jks sells adjustable sets in different sizes. i think they offer a set for 0" to 3" of lift.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #5 of 6 Old 07-02-2013, 05:52 AM
SlackJaw
baby jeep
SlackJaw's Avatar
You might post a pic of how your swaybar sets with that setup. Just to get a good concensus. I have 0"-2" discos and 2.5" springs and I want to say a 1" spacer for winch balancing and I'm perfectly fine...but I have no recollection how the 0"-2" links actually compare to the stock length. Short story is, there's a good bit of wiggle room for swaybar link length.
SlackJaw is offline
post #6 of 6 Old 07-02-2013, 06:24 AM
Gary2
From your description you have almost 3" of lift with stock links . For the cheap price why wouldn't you replace them . You wouldn't adjust an Anti-Rock 3" off and say good enough .
Gary2 is offline
