2 shops 5 mechanics and a 'star' tech..No clue why misfire - JeepForum.com
post #1 of 46 Old 10-25-2011, 12:47 AM Thread Starter
ljones628
I have a 04 wrangler TJ-Unlimited. 4.0L 6I. 100340 miles
It is throwing misfire in 1 and 2 codes. Jeep and my mechanic can't figure out why it's misfiring...it usually only misfires in idle - but if it does out of idle its at about 55mph. The check engine light is on and last night it started flashing at me repetitive and the truck started running like it did with the failed lifter. I continued to accelerate (figuring either will total it out and i'm done with it or would cause another symptom to help figure it out). It went back to running its "normal" after couple mins. I have been dealing with this for bout 6 weeks now. It ran great for 1k miles after the lifter job...ANY IDEAS WILL BE GREAT!! :
List of what has been repaired so far:
Valve lifters (12) replaced
Heads checked(apparently not valves though)
Heads reurfaced
Thermostat
Thermostat gasket and housing
New plugs
New coil pack
Fuel injectors cleaned
Battery
Fluids changed
List of what's been checked:
Fuel pump, lines, injectors
Plugs
Coil pack
PCM
Compression
Timing
Can't find any leaks (intake/outake)
Can't remember rest off hand...
ljones628 is offline
post #2 of 46 Old 10-25-2011, 01:03 AM
lookmanohands
I had a similar problem for the longest time and threw lots of new parts on as well. Rebuilt head, wires, plugs, injectors, cap and rotor. Misfire on cylinders 1 and 6 every time, and it would usually pop when I idled for a little while. It ended up being for me that the bolts on the underside of the intake/exhaust manifold were loose. I traced a slight whistle noise with a stethoscope to the underside of the intake and checked the bolts. They were loose enough to twist by hand. I think they had somehow worked loose over time after the head was replaced. Maybe like when they tell you to re-check the tightness of bolts when you replace suspension components. Worth a try.
lookmanohands is offline
post #3 of 46 Old 10-25-2011, 01:55 AM
Heath
2014 JK Wrangler
Camshaft position sensor module?
2013 JKU Rubicon
Heath is offline
post #4 of 46 Old 10-25-2011, 07:38 AM
LJameson
Did you put in a new cam with those lifters?
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #5 of 46 Old 10-25-2011, 09:20 AM
chris142
What kind of spark plugs were used? How was the head checked? Did they measyre the springs and ck them for being broken?
chris142 is offline
post #6 of 46 Old 10-25-2011, 09:29 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I'm not pointing my fingers at the plugs yet but exactly what model spark plugs are you running and when were they replaced? Before or after the misfire started?
Getting
Jerry Bransford is offline
post #7 of 46 Old 10-25-2011, 01:26 PM
herbiehind
leak down test done?
herbiehind is offline
post #8 of 46 Old 10-25-2011, 02:16 PM
loaderopp
I would move a spark plug and see if it moves the miss fire.....I had one bad plug out of 6 brand new.
Built not bought!!!
2005 Rubicon Unlimited, 5.5 inch custom long arm, 1 inch daystar body lift, River Raider Snorkel, Custom bumper/winch mount, sliders, tire carrier. 37x13.50 R17 Nitto Mudgraplers, Bushwacker flat fender. Custom 1/2 cab. Hyline hood vents. Custom tonnue cover and tool box. HID-X off road lights, LED driving lights custom rear bumper/m6000 rear monted winch.
loaderopp is offline
post #9 of 46 Old 10-25-2011, 03:57 PM
j_niko
2009 JK Wrangler
Cam lobe starting to wear down? That usually will cause an occasional backfire though.
2000 - Sahara
1997 - Sahara
j_niko is offline
post #10 of 46 Old 11-01-2011, 11:17 PM Thread Starter
ljones628
Yes cam been checked they said was good not new though.... spark plugs were in before lifter work done truck ran great for thousand miles after lifter work...the heads were resurfaced so the new gasgets would sit right I know they didn't check valves unknown on springs... can't find air leak..
post #11 of 46 Old 11-01-2011, 11:19 PM Thread Starter
ljones628
They put new cam sensor on and it still ran the same...
Jeep is now starting to run worse it sounds like a train in a sense with a hiss at times. It only does it in the mornings though. With or without warm up.
post #12 of 46 Old 11-01-2011, 11:23 PM
Boodyrider
Put in 6 new double platinum plugs, just try it.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #13 of 46 Old 11-01-2011, 11:23 PM
ColoradoCole
what do you mean by hiss ?
ColoradoCole is offline
post #14 of 46 Old 11-01-2011, 11:25 PM Thread Starter
ljones628
Tension pulley seems loose to me....the bolt on left side closest to firewall on top side the nut is not even touching the tip of valve cover I know certain order of tightening but can I redo that one without all the others? Can't hear air or not due to engine bouncing and loud chug sound
post #15 of 46 Old 11-01-2011, 11:29 PM Thread Starter
ljones628
I'll get plugs and try it
Hiss like have a air leak on right side but can't find it
random cylinder misfire, misfire 1,2,4,5,6? f100ranger TJ Wrangler Technical Forum 11 07-23-2011 10:56 PM
Error code P0306 misfire... but no misfire??? TJeep_1999 TJ Wrangler Technical Forum 4 06-03-2011 10:43 AM
Have No Clue???? mbojaj YJ Wrangler Technical Forum 24 01-13-2009 10:51 PM
Must Teach the Mechanics - For the love of God HELP (misfire problem) JeepsInParadise TJ Wrangler Technical Forum 11 08-18-2008 01:55 PM
I have no clue rubicon54 TJ Wrangler Technical Forum 3 11-14-2006 08:15 AM
