2 problems with the RC 2.5 lift - JeepForum.com
post #1 of 8 Old 06-24-2010, 08:03 PM Thread Starter
kooter1
I installed a RC 2.5 tonight… Love it so far, ride good and looks good.
It is on a 99 TJ with the 4.0l standard.
Two problems so far….
First is the steering wheel need lined back up, not sure if this is easy?
Second I installed the Transfer drop kit that came with the lift and not 2,4,and rev will not stay in gear unless I remove the shifter boot. It looks like since I drop the case the shifter is not to close to the rear of the plastic console hole. Is there an easy fix?
I will have pic later.
kooter1 is offline
post #2 of 8 Old 06-24-2010, 08:07 PM
SADISTIC
2011 JK Wrangler
Steering wheel is easy: use a deep-well 15mm socket, loosen both clamps on the drag link (near the pitman arm) and turn to straighten. Remove the drop kit, you should not need it.
SADISTIC is offline
post #3 of 8 Old 06-24-2010, 08:09 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
you need an alignment.
use washers instead of the spacers.
Mail crawling.
MisfitSeven is offline
post #4 of 8 Old 06-24-2010, 08:10 PM
jforse
Get an alignment. Dont use a t-case drop do it right and install a SYE and new d-shaft.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #5 of 8 Old 06-24-2010, 08:12 PM
MisfitSeven
MAiL Crawler.
the good thing about such a low lift is that you can get away with not running a SYE and new drive shaft. but this is the best way to combat drive line vibes.
Mail crawling.
post #6 of 8 Old 06-24-2010, 08:12 PM
jeep0312
The inner boot rubs on the body tub. My buddy just installed this on his TJ and had the same problem. We just moved the inner shifter boot higher on the shifter and zip tied it.
-Travis-
2004 Chevy Malibu, red, 2.2 ecotec, shiny wheels, loud stereo
2000 Suzuki SV650N, V-twin, Yoshimura Exhaust, Custom Rashed Paint Job...
jeep0312 is offline
post #7 of 8 Old 06-24-2010, 08:15 PM
MisfitSeven
MAiL Crawler.
this should be a temp fix only. you should put a piece of rubber hose on the stick where it is rubbing, then pull the inner boot back down to the stock location.
Mail crawling.
post #8 of 8 Old 06-24-2010, 08:17 PM
SADISTIC
2011 JK Wrangler
If you know what you are doing, you can get the alignment pretty darn close yourself. Here is a helpful link: http://www.jeepforum.com/forum/f9/en...g-read-663777/
Also, as stated above, use washers to lower your T-case if needed for drive shaft vibes (which you shouldn't have with a small lift); start with one or two washers on each bolt and see if that works, if not add another one or two and repeat
SADISTIC is offline
rc , rough country , lift , 2.5"
Lift Problems. Still. kb1kzd TJ Wrangler Technical Forum 15 02-22-2010 07:56 PM
problems on lift jk dparkhill JK Wrangler Technical Forum 12 09-12-2009 07:53 AM
lift problems dafireman4 YJ Wrangler Technical Forum 4 06-01-2009 03:30 PM
Tj problems after bb lift! alex71 TJ Wrangler Technical Forum 22 02-06-2006 10:59 AM
new lift and new problems johnWJ TJ Wrangler Technical Forum 34 10-04-2005 10:35 AM
