2 more Transmission Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2 more Transmission Questions
JK specific skid plates from Clayton Off Road Mfg.RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comStainless Steel Door Hinge Pins
Unread 02-13-2013, 06:58 PM   #1
682bear
Ok, I got the transmission out and seperated from the transfer case...
The first thing I noticed was the shifter housing on top is full of small pieces of busted up green plastic... maybe a bushing or something that the shifter moves in? Where would I get a replacement part? I would take a picture to post... but theres not enough left to photograph...
Second, the AX15 overhaul manual that I downloaded says once the shifter housing is removed, there is a retainer bolt visible that must be removed to take out the shift lever shaft and shift arm... when I removed my shifter housing, the top is solid... there is no visible retainer bolt... am I missing something?
This is in a 98 Wrangler, 4.0, with 5 speed...
Thanks -Bear
682bear is offline   Reply With Quote
