#1 | |
2" lift with 33's
Is it possible to run 33's with a 2 inch lift. (coils and shocks, not spacers) Would it still rub with tube fenders? I want to avoid a larger lift because of ride quality and cant afford a long arm. I searched but couldnt find any 2 inch lifts with 33's.
#2 |
Yes you can, but you'll need wheel spacers or after market wheels with about 3.75'' to 4'' BS. If you go with a 33x10.50 you'll be fine. Got a freind with 33's and a BB.
Steven |
#3 |
I have wheels with 3.75 BS I believe. You don't think 33x12.50 is possible?
#4 | |
33s are possible even compelely stock.
However stock, bumps suck. And with only 2'' of lift, then off roading is still not very possible. Ask me how I know.
If you live in Washington State, join my Group! http://groups.jeepforum.com/Washington_State_Jeeps Check out my current XJ build! Quote:
#5 |
I thought it would work out alright, I have 31's now and they do not rub. Going to a 33 would only add 1 more inch to the top of the tire. Maybe some bumpstop adjustments and trimming. Am I right?
#6 | |
Steven |
#7 |
Jeep Junky
It's possible but it won't look good and you will have very little ability to flex unless you have "high clearance" tube flares.
There's A LOT of suspension kits and suspension / BL kit combos out there that will get you enough clearance for 33s w/out sacrificing ride quality and w/out replacing arms... and not expensive! Unless you already have the tube flares you'll end up spending more on them then some of the lift kits that are out there. I would go at least 2.5" of lift for 33s if you go with the high clearance tube flares... or at least 3" of lift w/out the high clearance flares. Some popular kits / combos are.... - OME 2.5" suspension lift w/ JKS or RC 1.25" BL and 1" MML - RC 2.5" suspension lift w/ RC 1.25" BL and 1" MML - RC 3.25" suspension lift - BDS 3" suspension lift It's better to think "what's practical" vs "what's possible" Last edited by B2CARPEN; 09-16-2009 at 04:11 AM.. |
#8 |
Demonic Jeep Freak!
Throw on a Permormance Accessories BL for under $100 for added clearance.
2" lift with 33x10.50's. ![]() 2" lift and BL with 33x12.50's. ![]() |
#9 |
to me it is pushing it. you might need some sawzalling in the rear wheel wells.
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER] |
#10 |
you be the judge.... 33/10.5 x 15 no lift only trimmed front flairs
__________________________________________ Rusty Satellite Bch, FL 2005 Jeep Wrangler Unlimited (LJ) 6cyl, 4spd auto, dana 30/44 3.73, rear trac-loc, hard top, BFG AT 33/10.5 x 15 on rattle can black stock Ravine wheels, trimmed flares, budget PA 1" BL & RC 1" MML, Ford Explorer roof rack, Hella e-code headlight housings, 55 watt DDM HID Hi/Lo 6000k, EBC Yellow Stuff front brake pads, Platinum P4 battery, Rusty's 3" 305s front and 303s rear springs, RC rear track bar bracket and Hella 500FFs with DDM's 55watt 6000k H3 HIDs on windshield hinge brackets. Currie's front upper and lower control arms. Hummm whats next? Building a Dana HP30 with 4.88 and ? locker http://www.canddautocenter.com/ |
#11 |
Dammit, now ur putting Ideas in my head....
How much can u flex like this though??
Stu. '06 Sahara, on Koni's and KM2's '84 Mk1 Golf Rust Rod |
#12 |
You can always go the mudb8 way and do a DIY Highline Mod...
DIY High Line Hood Mod for cheap : Higher Ground 4×4 |
#13 |
I ran 33x12.50x15s on 3.75 backspaced AR rims on a stock '01 Sport for while. They didn't rub on the control arms and didn't rub fenders or flares going over even the worst bumps. However, when it flexed: forget about it. Super stuffage.
I added a 2" BL, and it looked much more proportional and definitely gave it more room to flex. *Might* could get by offroad if I didn't disco. Still wasn't really enough though probably. (This go-round I'm going with a smallish suspension lift and 1"BL/MML.) good luck! ![]()
OME 2.5" HD|285/75R16 Nokian Vatiiva M/T|Skyjacker Hydros|JKS Front Control Arms|JKS Upper Rear Control Arms|1" PA BL|1" Brown Dog MML|Novak 241OR Cable Shifter Linkage Red Jeep Club Member #565 My Registry Profile For Sale: Cordless Snap-On Impact Wrench WTB: UnderCover Fab No-Body Lift Skid Plate WTB: Rokmen or Currie Control Arms ↑ PM me! Ever had Death Wobble? Please respond to the poll here! |
#14 |
look up "zoneoffroad.com" they have wallet friendly lift kits and my two inch spacer is awesome, about to get the four inch
#15 |
Wasabi!
Just get a RC 2.5 lift and jks 1.25 BL with 1"mml, best way to clear them 33's nicely, plus theres a bunch of people that have pics of that set up. Some even run 35's with that set up
Currently 04 Sahara: 3" BDS lift, 9500 BDS Monotubes, Flowmaster Super 44, Olympic Rocker Guards, 33" Duratracs, 15x8 Black Rock Blades. http://www.yoco-offroad.com Khaki Jeep Club Member In Pennsylvania, fun is illegal Xbox live GT - TheExecutive00 Tama, Paiste, DW, Zildjian, Vic Firth....yes I go boom boom! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
