2" lift with 30's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2" lift with 30's?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-08-2009, 06:08 PM   #1
MC_NickP
2" lift with 30's?
hey guys. i just bought a set of 30" courser AT's, and dont plan on buying new tires for a while. would 30's look ok with a 2" lift?
Black 98 TJ
Low Output 4 Cylinder Jeep Club #178
build thread:
http://www.jeepforum.com/forum/f22/m...4/#post9499802
MC_NickP is offline   Reply With Quote Quick reply to this message
Unread 01-08-2009, 06:09 PM   #2
HipCheck_1
yeah, I think it would...
05 Jeep Wrangler 2.4l 4 cylinder
3" SL, 2" BL, 33 Eng belly up, 33x12.5 Pro comp MT
Low Ouput 4-cyl Jeep club member #151
HipCheck_1 is offline   Reply With Quote Quick reply to this message
Unread 01-08-2009, 07:29 PM   #3
bayvilleYJ
i run 33 13.50 tsl's with 0 inches of lift.
bayvilleYJ is offline   Reply With Quote Quick reply to this message
Unread 01-09-2009, 10:16 AM   #4
Faramir66103
I'm planning a 2"-3" lift and am running 30" BFG ATs. I think it may look a little goofy, but not much. I saw a couple TJs on a trip this last week that I'm pretty sure were on 30"s with 2"-3" lifts and it wasn't as goofy as I'd thought it would be. I can't afford new tires with the lift, so I think I'll just live with it. I want to run 33"s offroad eventually. I'm considering getting the 33"s put onto some inexpensive rims and only using them for the offroad trips and keeping the 30"s on for daily use in order to keep the mileage as good as is practical. We'll see.
FWIW,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline   Reply With Quote Quick reply to this message
Unread 01-09-2009, 10:18 AM   #5
BlueTJ28
I have a 2 inch bb with rubi springs and 30's. I think it looks fine. If I can ill try and take some oictures and post them up.
BlueTJ28 is offline   Reply With Quote Quick reply to this message
Unread 01-09-2009, 11:08 AM   #6
TheBoogieman
Evil Inside!
TheBoogieman's Avatar
Yes.I had 31's with a 2" lift way back.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 01-09-2009, 11:08 AM   #7
HipCheck_1
Most everyone builds in stages. If you have smaller tires cause you just added a lift and couldn't afford both at once so be it.
If someone tries to clown you just tell them STFU.
