2 inch spacer lift vs 4 inch suspension lift and Death Wobble - JeepForum.com
post #1 of 38 Old 03-08-2011, 10:42 AM Thread Starter
BadKarma1701
I have 2001 Sahara with 82.000 miles and it is bone stock. I want to lift it and was looking at the zone 4 inch suspension lift. I have read all about death wobble on here and a guy came into my work with a 4 inch superlift. He said dont lift. it, that he gets DW at 45 and 60 mph. To be fair 2 rear and 1 front of his 33 inch tires were bald as all get out. I have crap luck, so i think if i lifted it i would get DW, the idea of this scares the crap out of me. much less paying all that money just to get a dangerous ride. So now i am almost going to go with a 2 inch spacer lift, even though it is not what i want. ok so heres my questions.
Do all TJ'S get DW when lifted?
with 82.000 miles is it more likely to get DW?
Will a spacer lift caues DW?
How much lift do you really get out of a 2 inch spacer lift?
Thanks for covering all 4 questions
HONOR, TRUTH, LOYALTY, JUSTICE. DEEDS, NOT WORDS.
"I came into this world kicking, screaming, and covered in someone else's blood and I'm damned sure going out the same way!"
Sienna Jeep Owners Member #56
BadKarma1701 is offline
post #2 of 38 Old 03-08-2011, 10:46 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
No all TJs don't, when lifted properly.Did this guy explain what his 'Death Wobble' felt like to you?He obviously didn't set his jeep up properly.
GOLENJEEPTJ is offline
post #3 of 38 Old 03-08-2011, 10:50 AM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
Everything you just said is crap!You HAVE to align the toe in to 1/8" after any lift or it might not be driveable. DW doesn't happen at certain speeds,not balancing your tires does.Bald tires will give it to you with no lift.Lift your Jeep,align the front end(toe in)yourself in 10 minutes and ride on.Get the Zone 4.25" combo lift for a great riding Jeep.I have that with 35's.
TheBoogieman is offline
post #4 of 38 Old 03-08-2011, 11:00 AM
B52dude
I have a spacer lift. No wobble at all.
#1 As mentioned-- No
#2 I hope not, cuz mine has 78K. But none as of yet.
#3 For the most part, no. Unless your suspension components need help in the first place.
#4 Depends on the brand. I went with Crawler Ready, and they have legit 2 inch spacers. Rubicon Express comes with 1.75 inch spacers, even though they say its 2 inches.
Hopes this helps.
Originally Posted by Ripper3494 View Post
i think we should chase him around with yjs, its like being chased by zombies, slow, crippled but for some reason still scary as heck lol
Red Jeep Club #614
B52dude is offline
post #5 of 38 Old 03-08-2011, 11:42 AM Thread Starter
BadKarma1701
Everything i said was crap? What part? That I have a sahara with 82000 miles? I have read about DW? That a guy came in with a 4 inch lift, 33 inch bald tires and said he got DW with his 4 inch lift? Or that i have crap luck?
post #6 of 38 Old 03-08-2011, 11:48 AM Thread Starter
BadKarma1701
The guy said it felt like he was going to crash at 60 mph and at 40 mph that was about it for a explaining and he stated a shop put it on for him. he did not say if he got it aligned, his mileage or if he beats his jeep.
post #7 of 38 Old 03-08-2011, 11:49 AM
Strossy
All anyone is trying to say is that it doesn't matter what brand or size lift you go with, after it's finished it needs to be properly aligned ( preferably 1/8th toe in) and you'll be just fine. The alignment gets thrown way out of whack when you put the lift on, if it's not corrected expect "death wobble".
All things in Modification
Strossy is offline
post #8 of 38 Old 03-08-2011, 11:58 AM
05TurboS2K
I had DW with NO lift, completely stock jeep.
I lifted with a spacer 2" and got new tires and guess what NO DW!!!
I guess that means lifts = DW cure.
The truth is, tire balance is the problem and when I bought new tires they were balanced properly and the originals weren't.
05TurboS2K is offline
post #9 of 38 Old 03-08-2011, 11:59 AM
biffgnar
biffgnar's Avatar
This is a bit of an oversimplification. Yes, alignment is important after a lift, but DW can still come with a perfectly aligned vehicle if steering components are wearing out (which is where higher mileage could come into play). But as others have said DW definitely not automatic and should be addressed if it arises.
biffgnar is online now
post #10 of 38 Old 03-08-2011, 12:10 PM
Strossy
"I had DW with NO lift, completely stock jeep.
Strossy is offline
post #11 of 38 Old 03-08-2011, 12:15 PM
thirdeye
DW wobble is always an on going thing. Especially when you wheel alot, and even more when you're riding stock steering and the miles are gettin high. The joints gotta go sometime.
Death wobble can always be cured, sometimes its just hard to find the exact cause.
If you're jeep is set up right and aligned properly after your lift install, there should be no problems. Take driveline into account also
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #12 of 38 Old 03-08-2011, 12:58 PM
biffgnar
biffgnar's Avatar
Driveline vibes are a problem that should be addressed but they are a separate problem from DW.
post #13 of 38 Old 03-08-2011, 01:35 PM
thirdeye
correct. Just sayin it needs to be addressed when properly setting up a jeep or it won't drive nice either.
thirdeye is offline
post #14 of 38 Old 03-08-2011, 02:01 PM
tjhawx
I've had the DW before and it was on a bone stock TJ unlimited with less then 50K miles. The fix was the steering stabalizer shock. I replaced that and it went away instantly. All research I've done on DW has pointed at the steering stabalizer.
tjhawx is offline
post #15 of 38 Old 03-08-2011, 02:28 PM
biffgnar
biffgnar's Avatar
You must not have done much research then. Stabilizer will cover up other problems, but it is not the cause of DW.
4 inch Suspension lift and 2 inch coil spacer? Nick716 TJ Wrangler Technical Forum 8 05-30-2011 10:47 AM
1 inch body lift, 3/4 inch front spacer, 33's? vanner77 JK Wrangler Technical Forum 5 08-17-2009 02:38 PM
4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? ECUSAE20 TJ Wrangler Technical Forum 11 05-08-2009 10:12 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
1.5 inch spacer and i inch body lift is this a good lift? magnum629 TJ Wrangler Technical Forum 7 02-11-2006 10:16 AM
