Quantcast 2" coil spring spacers with my lift?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2" coil spring spacers with my lift??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 04-15-2007, 08:50 AM   #1
RBurg44
i want to add 2" spacers in my coil springs but i dont know if they with work the the aftermarket lift i have the 4" rough country sus. lift will it work or what????
4.0L, 5 speed manual, D35 w/ 3.73's, 4" ruff county sus. lift, 33X12.5 Cooper Discoverer's, rubicon style rocker panels, kc front bumper loop with 130w 6" slimlites, Delta 7" Xenon Headlamps,
RBurg44 is offline   Reply With Quote
Old 04-15-2007, 10:50 AM   #2
ILLgreenjeep
no it wont work, the suspension package isnt designed for an extra two inches, i did the same with mine and it rode horrible, and messed up the steering angles. just put in a body lift in place of the coil spacers
ILLgreenjeep is offline   Reply With Quote
Old 04-15-2007, 01:32 PM   #3
McLovin
1991 XJ Cherokee
It wouold work if you added a add on long arm suspension. Otherwise better go with a BL.
McLovin is offline   Reply With Quote
Old 04-15-2007, 01:44 PM   #4
beryl
and don't forget the cv driveshaft and sye...just go with a 1" BL
beryl is offline   Reply With Quote
Old 04-15-2007, 11:55 PM   #5
watkins 92 yj
i did mine and it worked fine... although i have about an extra 150lbs sitting on the front with my custom bumper and winch... i didn't put them on the rear. i just did the front to level every thing out..
watkins 92 yj is offline   Reply With Quote
Glock Forum
