#1 | |
2"coil spacers + 2"OME springs?
I currently have a 2"REBB running 33's. I'm looking at these used 2" OME springs and planning on replacing stock springs with these under the BB coil spacers. Now, the questions...
Will 2" BB shocks fit my plan or do I have to get new longer shocks? If so, which one? What other parts or mods I need to do, to make my plan work? Please give the must and what I can go without. Will a TC drop work temporarily until I get a SYE? Adjustable trackbar needed? What else ????? Thanks ! ![]()
#2 |
you´ll have 4" of lift witrh that set-up.
i think you´ll have to drop the TC for about 1.5"-2" with that. with 4" lift you need 4" longer shocks. the shocks you have now are too short then. you also need longer sway bar end links and longer brake hoses with 4" of lift. a longer/adjustable track bar is recommended.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer 35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA 12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan Jeep TJ Runicon Pics www.timbercrawler.de |
#3 |
You may need adjustable rear upper control arms too. I am not sure about front uppers. You might want to consider a kit for a lift like this.
#4 |
If it were me, I'd get the OME 2" springs, then get a set of 1" spacers instead of your RE 2". That will put you right at 3" of total lift which will clear the 33's, but avoid many of the problems you'll encounter by going to 4" of lift and you should be able to continue using you existing 2" shocks.
#5 |
As for longer shocks, is there a way to tell if the shocks are going to be too short after you change something? Could you disconnect the sway bar and just jack up one side to see if the shock will extend all the way or is there another reason for the shock to be longer? Just wondering. Thanks
IF YOU THINK YOU KNOW IT ALL, YOU HAVE A LOT TO LEARN. IF YOU KNOW YOU KNOW IT ALL, YOU WILL NEVER LEARN!!! |
#6 |
You could get a set of Bar Pin Eliminators. That will give you about 3/4 to 1 inch on your shocks.
#7 | |
#8 | |
RE 3.5 Super Flex, Old Man Emu Long Travel Shocks and Steering Stabalizer, RE Hack & Tap SYE, AA CV Drive Shaft, ARB Compressor, ARB Front and Rear Lockers, 35x12.5x15 Cooper STTs, Custom Fabbed Bumpers, ORFAB rear tire carrier/ gascan holder, Superior 4.88s, and Heated Seats Last edited by the_ronster; 03-04-2007 at 10:31 AM.. |
#9 |
If you're looking at buying 2" spirngs to add to your BB, then why not look for 4" springs, and sell your BB. Much better in my opinion.
You will still most likely need a boatload of other stuff though. Possibly some or all of: control arms trackbars/trackbar brackets shocks t-case drop / SYE CV DS extended brakelines longer swaybar links |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
