2" Budget Boost or just Spring Spacers? - JeepForum.com
post #1 of 7 Old 10-19-2007, 07:32 AM Thread Starter
hikerpaddler
hikerpaddler's Avatar
I'm about ready to add a couple of inches to my 98. I do not plan to run discod, nor do I plan to go higher, as this vehicle spends a lot of time on pavement as well as dirt. Should I get a 2" kit, or since I don't plan on disconnecting, is it better to just get spring spacers?
hikerpaddler is offline
post #2 of 7 Old 10-19-2007, 07:49 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
In your situation, I would base your decision on the condition of your current shocks.
If they are relatively new and are in good shape, go ahead and just get coil spacers.
If your shocks are showing some age and have a few miles on them, I'd take the opportunity to get a complete BB with shocks.
Wheelin98TJ is offline
post #3 of 7 Old 10-19-2007, 07:50 AM
Rocky529
Rocky529's Avatar
Either way, it is essentially the same thing. I recommend the BB just because it is cheap and gives the same results as a full lift kit (minus the adjustable track bars or new control arms, which aren't really necessary for just 2").
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #4 of 7 Old 10-19-2007, 07:58 AM Thread Starter
hikerpaddler
Thanks for the advice. The install doc for Trailmaster spring spacers dictates disconnecting the front driveshaft, and the front control arms. That's not really necessary, is it?
post #5 of 7 Old 10-19-2007, 08:01 AM
Wheelin98TJ
JEEP FREAK
Nope, not necessary.
Just disconnect the sway bar links and the shocks and you'll have enough droop to get the spacers in.
If you still have problems getting them in, next disconnect the track bar.
post #6 of 7 Old 10-19-2007, 08:03 AM
SouthFLJeeper
SouthFLJeeper's Avatar
I just completed the TrailMaster kit yesterday. I didn't have to disconnect the driveshaft but did have to disconnect the lower control arms. I already had 2.5" Rancho lift springs so you might be able to do it w/out doing the control arms. Try it without and see if you can get the springs back in. If not you can always disconnect them.
'00 TJ Sahara - 1" Body Lift, awaiting many upgades
'00 TJ Sahara (R.I.P.) - 2.5" Rancho Lift, 2" BB, 1" Body Lift, 35" XTerrain's, Warn 9000lb Winch, Warn Bumpers & Sliders
'05 Excursion 6.0 Diesel
SouthFLJeeper is offline
post #7 of 7 Old 10-19-2007, 08:07 AM
SouthFLJeeper
Here's a couple of pics from the installation.
3/4" Spacers With Budget Boost? shay4au TJ Wrangler Technical Forum 2 06-24-2009 02:14 PM
2" BDS vs Budget Boost bsa127 TJ Wrangler Technical Forum 29 05-24-2009 04:05 PM
Budget boost or RC 2.5 spring lift JeromeJGarcia TJ Wrangler Technical Forum 5 12-13-2008 07:19 AM
coils instead of spacers on a budget boost? Jeepkid09 TJ Wrangler Technical Forum 4 09-07-2008 02:40 PM
Spring Compressor or Budget Boost? Achillius TJ Wrangler Technical Forum 3 01-19-2008 12:09 PM
