Quantcast 2" Body Lift Installation Advice Needed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2" Body Lift Installation Advice Needed
1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSpartan Lockers FREE SHIPPING Excellent Prices
Old 10-24-2007, 10:34 AM   #1
fisher836
I am installing a 2" PA Body lift. For those of you who have done it, I'm curious if I need to worry about any of the following... AC lines, installing the T-case linkage bracket, the fuel line extension hose, or any other aspects.
I was really wondering if it's a matter of just sticking the spacers in for the BL and adding the bolts or if it's much more extensive than that. I have a 1" ML already installed.
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline   Reply With Quote
Old 10-24-2007, 10:47 AM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
For a 2", likely all of that... which is one reason I chose to go with only a 1" PA BL.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 10-24-2007, 12:43 PM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
When the King speaks (Jerry,not Elvis),no other replies are needed
TheBoogieman is offline   Reply With Quote
Old 10-24-2007, 12:56 PM   #4
Chris_
You've got something hanging off the end of your nose.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline   Reply With Quote
Old 10-24-2007, 01:06 PM   #5
jsbarks
and its brown...
jsbarks is offline   Reply With Quote
Old 10-24-2007, 01:25 PM   #6
RnEmOvr
Never Forget
RnEmOvr's Avatar
i put the PA 2"BL on mine and few things, yes you will need the shift linkage, you only need some of the fuel line extension, yes you need the steering bracket (included) and it includes rad drop brackets that are super easy to do, and will place your shroud back where it currently is, i took about 3 hours to do mine, and that incleded cleaning it and getting food, so actual time was closer to 1.5 hrs
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 10-24-2007, 01:29 PM   #7
Jerry Bransford
Remember to not take all the body mount bolts out at once because if you do, lifting one side via a jack to insert the spacers could cause the body to slide out of position. Getting it repositioned is a royal PITA. Leave a few bolts loosely threaded in on the opposite side you're inserting the spacers in so everything will remain in alignment.
Getting Savvy...
Old 10-24-2007, 01:31 PM   #8
RnEmOvr
Never Forget
RnEmOvr's Avatar
good point jb, to the OP if you have the PA directions use them they are VERY detailed and have lots of pics,
www.cityprofile.com
Old 10-24-2007, 01:41 PM   #9
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I did not use the steering shaft spacer with my 2" BL.
Its been this way for 8 years now with no problems.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Glock Forum
