2" BL ontop of a 4" susp lift, preperation, ect - JeepForum.com
post #1 of 11 Old 10-23-2006, 07:20 PM Thread Starter
YCP4x4
YCP4x4's Avatar
So i have a 4" Superlift on my 03 rubicon and a friend of mine is selling a set of 4 35" Baja claws on cragle (spelling) rims and a 2" Body lift. I am thinking of purchasing these, do you think ill have to do anything other than install the BL and get the tires done up and alignment? It's a Rubicon model.
Thanks ahead of time,
Brian
2003 Rubicon ** SOLD **
4" Superlift
35" Mickey Thomson Baja Claws
YCP4x4 is offline
post #2 of 11 Old 10-23-2006, 07:27 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
i have a 4" lift and 2" BL and could easily clear 35 with proper bump stops
RnEmOvr is offline
post #3 of 11 Old 10-23-2006, 07:29 PM Thread Starter
YCP4x4
YCP4x4's Avatar
i am not worried about clearing it at all. That's not the problem, i just want to make sure i don't need to pick up anything extra other than the BL itself.
I actually just left the stock bump stops in when i did my 4" susp lift. The ones that came with the kit wouldn't fit, even with shaving
4" Superlift
YCP4x4 is offline
post #4 of 11 Old 10-23-2006, 07:31 PM
UTWeezul
They will fit fine and you've got good axles to handle the 35s. Be sure to post pics when they are on. I really want to step up to 35s but need to see if they will fit first. I might be adding another inch of BL to fit them.
Edit: You may eventually want to upgrade to a Currie HD Steering but won't be necessary right away, unless you damage it off road
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #5 of 11 Old 10-23-2006, 07:39 PM Thread Starter
YCP4x4
YCP4x4's Avatar
just an excuse to upgrade..
4" Superlift
YCP4x4 is offline
post #6 of 11 Old 10-23-2006, 07:41 PM
UTWeezul
You've gotta love those "excuses" don't ya!
35" MTR Kevlars
103" Wheelbase
UTWeezul is offline
post #7 of 11 Old 10-23-2006, 07:43 PM Thread Starter
YCP4x4
YCP4x4's Avatar
oh yeah, think ill be ok with those stock bump stops i have in? i went and found 2 out of the 4 of the ones that came /w my lift. Im going to start shaving them (i do believe i left the other 2 at my friends place)
4" Superlift
YCP4x4 is offline
post #8 of 11 Old 10-23-2006, 07:45 PM
RnEmOvr
RnEmOvr's Avatar
you can buy b/s from RE i would put them in to keep from over compressing springs
RnEmOvr is offline
post #9 of 11 Old 10-23-2006, 07:47 PM Thread Starter
YCP4x4
YCP4x4's Avatar
i have them, just a matter of finding them, fairly sure my friend has my other 2 in his garage lol
4" Superlift
YCP4x4 is offline
post #10 of 11 Old 10-23-2006, 07:47 PM
alex71
I would just put a 1in body lift or no body lift. I have a 3inch sl and one inch bl and clear 35's just fine
2001 jeep wrangler sport / Waggy 44 /FORD 8.8. lockright/ 4.88 / 3/2'' lift,Stretched to 100.5/ Warn x8000i / 35in BF KM2's / AtoZ rockers, cage,/ Poison spyder crusher corners.
Vote for TJOFTY!
alex71 is offline
post #11 of 11 Old 10-23-2006, 07:51 PM Thread Starter
YCP4x4
YCP4x4's Avatar
thing is im getting a good deal because it's from a friend.
4" Superlift
YCP4x4 is offline
How Is A 2" Susp. Lift Any Different Then A 2" T-case Lift? rastaangel TJ Wrangler Technical Forum 4 06-19-2009 08:33 PM
From 2 " BB to 2" susp. lift Badawee TJ Wrangler Technical Forum 10 06-13-2008 02:08 PM
2" BB plus 1"BL or 2.5" Skyjacker susp lift plus 1"BL JAXTOY 2 TJ Wrangler Technical Forum 12 03-23-2005 06:50 AM
with 3" susp lift can i add 2" Bomerang shackles without mods to drvshaft yoke? ookxtreme YJ Wrangler Technical Forum 2 10-02-2004 09:47 AM
Susp Lift Question for 2"-3" w/ 2.5L ssg11bravo30 TJ Wrangler Technical Forum 10 07-04-2002 02:36 AM
