2" BB Lift and TC Dropped...Can I do a 1"BL? - JeepForum.com
post #1 of 10 Old 11-12-2007, 08:51 PM Thread Starter
djt283
djt283's Avatar
I've got a 2" BB lift (spacers/shocks) and I dropped the TC to stop some vibrations. Everything is good now but I'm buying tires this week and I want to have a little more clearance.
If I add a 1" BL do I have to remove the TC drop or can I run like that for a while? Also, If I have the 1" BL with the TC dropped, is a MML still needed?
Thanks for the help.
djt283 is offline
post #2 of 10 Old 11-12-2007, 10:00 PM
john NC
john NC's Avatar
the BL will have no impact whatsoever on the TC drop and/or driveline vibrations, it's just lifting the tub off the frame so you can leave the TC drop
you'll still need a MML, a BL would just make doing both at the same time easier. i'm gonna do both once i save up for some new tires. i have a brown dog mml sitting in the closet but a 2" BB + 1"BL would look pretty silly on 30s lol (not that it doesn't already)
john NC is offline
post #3 of 10 Old 11-12-2007, 10:04 PM
eclipse27
you dont hafe to have a mml....most 1in kits come with radi drop brackets. You can just use that. A mml would help with driveline angles....but isnt needed.
4-4.5 inch susp. lift. 1 in performance acs. body lift. 5 in offroad foglights. Brushgaurd. Atoz corner armors.Round 4in taillights.D35/30 combo. upgraded horn.radio.8inbazzoka tube.highlift jack. 1.5in wheel spacers. 33' goodyear wrangler mt's.
eclipse27 is offline
post #4 of 10 Old 11-12-2007, 11:34 PM Thread Starter
djt283
djt283's Avatar
So if I understand what everyone's saying, with my current setup, a 1" BL doesn't change anything, as long as I drop the radiator shroud to account for the lift?
Just want to make sure before I add something I don't need and screw up the other stuff I don't need (but already have).
Thanks for the help!
djt283 is offline
post #5 of 10 Old 11-12-2007, 11:59 PM
Rocky529
Rocky529's Avatar
You are correct.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #6 of 10 Old 11-13-2007, 12:08 AM Thread Starter
djt283
djt283's Avatar
Originally Posted by Rocky529
You are correct.
Thanks. From your profile it looks like we're running nearly identical setups and I'm about to buy the same tires you've got. If you don't mind, I've got a few questions that I've already asked on here but one more opinion can't heart (you may have already answered these, if so...I'm sorry)
I've got the Canyon rims...same size as yours. My 30x9.5's are a little less than an inch from the rear springs. I have to do something. New rims are cheaper than good spacers. How did you deal with that?
Lastly, did the Performace Accessories lift come with the bracket to lower the radiator shroud?
Thanks for all of your help.
djt283 is offline
post #7 of 10 Old 11-13-2007, 12:16 AM
Rocky529
Rocky529's Avatar
I have the same exact specs on my Ravine wheels and love them and wanted to keep them. With 5.5" of backspacing, any tire 11.5" or wider requires wheel spacers, so I have Spidertrax 1.25" wheel spacers all around to prevent any rubbing. You can buy new wheels with the proper backspacing too.
Yes, it came with all necessary brackets, including the t-case shifter re-location bracket. Don't install this bracket until the lift is complete and you have tested the shifter, not every Jeep needs this particular bracket after a 1" body lift.
Rocky529 is offline
post #8 of 10 Old 11-13-2007, 12:20 AM Thread Starter
djt283
djt283's Avatar
Thanks. I already dropped my TC and installed a similar brackt after my 2" BB lift caused vibrations.
Just a question. Crager Wheels and center caps are about the same price as 4 spacers. Any advice which is better? (I also like my Canyons)
djt283 is offline
post #9 of 10 Old 11-13-2007, 12:22 AM
Rocky529
Rocky529's Avatar
There is nothing better, wheel spacers are just as good as new wheels... although some will disagree.
As long as you torque them to 100 ft/lbs and re-torque the wheel spacers after 50 miles, you are fine. So if you really like the Canyons, get wheel spacers without thinking twice.
And if you're going to install a body lift and have a t-case drop, I suggest you install a 1" MML to go along with it. It will most likely allow you to completely remove that t-case drop, and it is a huge advantage in installing a MML. The 2" BB does not need that much t-case drop (usually not any), so a 1" MML would most likely cancel out any t-case drop on your Jeep and you will be vibration free still. It's only $100 or so, and would also eliminate the need for you to drop your radiator (although it is no big deal). Take a look at Daystar, MORE or Brown Dog motor mount lifts.
Rocky529 is offline
post #10 of 10 Old 11-13-2007, 12:25 AM Thread Starter
djt283
djt283's Avatar
Thanks for all the help.
djt283 is offline
Please noob-proof this setup -2" BB, 1" Body Lift, 1"Motor Lift jondotcom TJ Wrangler Technical Forum 10 03-06-2010 02:43 PM
can i temporarily not use a dropped pitman arm with my 4" kit? SteveJcoYJ YJ Wrangler Technical Forum 4 02-03-2010 05:44 PM
"project Cheap Jeep" - 5-6" Lift - Looking For Oem Shocks For "xx" Lift Jeepwood YJ Wrangler Technical Forum 4 11-26-2009 07:32 PM
OME 2" lift and 1.25" body lift. Gives good ride - adequate clearance for 33" tires? CB3 TJ Wrangler Technical Forum 30 11-25-2009 12:13 AM
