2" BB Help please - JeepForum.com
post #1 of 19 Old 06-05-2011, 05:13 PM Thread Starter
Agent620
2" BB Help please
So about 9 months ago I put on a 2" BB ((((This is the BB used http://www.4wd.com/Jeep-Lift-Kits-Je..._pn=W%2fI30721 ))))) and it looked like this
http://s225.photobucket.com/albums/d...rrent=0000.jpg Sorry but the IMG code isnt working for this picture.
Then 4-5 months later I was told it was in the wrong place. So now it sits here at the top with no bumpstop because there is no hole for the bumpstop to go through.
Now a few months even later and the spring is contacting the side and pushing the base out.
Tell me if it needs to go back on the bottom of the spring (I think it does) or should it stay on top and spread out? It never had contact or spread out on the bottom.
Agent620 is offline
post #2 of 19 Old 06-05-2011, 05:23 PM
saint_louligan
Those spacers go above the spring like you currently have them, not below the spring like they were before.
It looks like they are rubbing on the front face of the rear springs, which is not a big surprise - the rear springs are not perfectly straight nor vertical. They curve slightly to the front - right where that light contact is happening.
It's not a problem at all, provided that the spacer doesn't start to deteriorate significantly.
saint_louligan is offline
post #3 of 19 Old 06-05-2011, 05:50 PM
Mike_Motorbike
Those are weird spacers.....
You have got to have bumpstops.
If not you will blow out your shocks or even worse , brake a shock mount off...
Did they measure a full 2" ?? If so did you get new shocks.
If so You probly need bumpstop extensions.
That kit looks fishy....
JEEPING .....The art of getting dirty and going broke while slowy heading nowhere and taking all day to do it.....
2001 TJ 31"s 4.0L Auto , Blue , Soft Top , Full Doors. Home made BB 1 3/4" front 1" back...quick discos
Mike_Motorbike is offline
post #4 of 19 Old 06-05-2011, 06:25 PM Thread Starter
Agent620
Yes I got new shocks, it did give me the 2" as well. So I have several people now saying to keep the spacers where they are and one that says I need bump-stops, if I put the bump-stops back on I will need to move the spacer back to the bottom. I do not have 2" bump-stop extensions for the 2" bb. Do I need them with the BB or am I good without? Should I keep it on-top of the spring or move the spacer below?
Agent620 is offline
post #5 of 19 Old 06-05-2011, 11:08 PM
saint_louligan
According to the instructions, no bumpstop is needed, but it looks pretty fishy to me without something other than the spacer itself (granted, it does have a slight extension in the middle).
Here's what I'd do...
Disconnect the rear swaybar.
Remove the lower spring retainers (if any are there - mine didn't have rear retainers)
Jack-up the frame until the rear spring is loose enough to remove. If the rear wheel lifts first, then you may need spring compressors to remove it.
SLOWLY lower the jack, keeping an eye on the rear shock on the side where the spring has been removed... you want to test to see what the suspension travel limiter is. I'll bet it will be the shock before anything else.
If the shock is the limiter, you need some bumpstop AND you now know how much you need - just measure the space between your rear spring spacer (the lift spacer) and the lower spring perch and add .5 to .75 inch.
Buy aftermarket bumpstops (or fab something yourself) and install them on the lower spring perches. Most online vendors will list the dimensions of the bumpstop so you can get the right height for your situation. You just drill a hole in the center of the lower spring perch and bolt them on.
post #6 of 19 Old 06-05-2011, 11:36 PM
Mike_Motorbike
OK with longer shocks for a 2" lift , you'll need 1" (or so)(maybe 1.5") bumpstop extension.......
It looks like you could just drill the center of that little extension and put the bolt from the original bumpstop through it and that would get it.... You may need a longer bolt though......
Like the last guy said you need to see were your shock bottoms out and make sure the bumpstop stops it , at least 1/4" before that.....
post #7 of 19 Old 06-06-2011, 09:16 AM Thread Starter
Agent620
When lowering how will I know what the limiter is without blowing my shock out? Do I need my tire off for this or do I leave it on? Should I just do the hockey pucks for the extensions or go aftermarket like JKS, Teraflex, or RE?
Agent620 is offline
post #8 of 19 Old 06-06-2011, 05:31 PM
saint_louligan
If you take it slowly, you won't damage the shocks.
After removing the sway bar & spring, you can either leave the wheel on and raise/lower the frame OR put the frame on jackstands and raise/lower the axle.
If you go aftermarket, make sure they mount to the bottom. You may, like the previous poster noted, be able to use the OEM bumpstop. I expect that upper cup (the 2" lift itself) is polyeurethane and somewhat pliable. If it's soft, the bumpstop puck material can be solid like steel or aluminum. Even a body lift puck would work.
post #9 of 19 Old 06-06-2011, 05:57 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
x2.
needs bumpstop extensions bad. I don't care what the instructions claim, keep in mind they may have been written by morons. you need bumpstop extensions, especially in the rear with spacers.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #10 of 19 Old 06-06-2011, 06:06 PM Thread Starter
Agent620
x2.
My spacers are nothing like those and I never received instructions in the package or could find it online. I guess I will order bumpstop extensions and then move the spacers back to the bottom once I get them. Or should I just do the hockey puck extensions? Thanks for all the help.
Agent620 is offline
post #11 of 19 Old 06-06-2011, 06:09 PM
Unlimited04
Spacers go on top. always.
bumpstop extensions need to be at least the same length as the spacer in the rear.
for the rear, get Performance Accessories "Mini-Block" body lift spacers, and longer bolts from the local hardware store. thats what budget boost companies use.
www.performanceaccessories.com click shop now.
Useful Write-Ups:
Funny:
post #12 of 19 Old 06-06-2011, 06:19 PM Thread Starter
Agent620
Thanks, but I cannot use my spacers and bumpstops together, because the spacers do not have holes for the bumpstops to pass through. In order to use bumpstops I will either need to move the spacers to the bottom of the spring, or get new spacers(which I would hate to do, but if I must I will).
Agent620 is offline
post #13 of 19 Old 06-06-2011, 06:26 PM
Unlimited04
You own a knife?
Useful Write-Ups:
Funny:
post #14 of 19 Old 06-06-2011, 06:31 PM Thread Starter
Agent620
You own a knife?
Yea, better hope it doesnt ruin my spacer.
Agent620 is offline
post #15 of 19 Old 06-06-2011, 06:33 PM
asa
asa's Avatar
if you want i am taking off my old BB i can give you the rear spacers.
2000 Sahara
SYE,Rough Country 4" X series lift, Currie HD Steering, Solid Diff Covers,Rough Country Steering Stabilizer, Poison Spider Steering Box Skid, Skid Row oilpan skid, Brown Dog 1 Inch Motor Mount Lift, JKS 1.25 Body Lift, JKS Quicker Disconnects, Currie HD Tie Rod, Optima Red Top Battery, Garmin Nuvi 200W GPS
NJM#48
asa is offline
budget boost , help please
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 11:54 AM
E-brake only stops the jeep when going in "R" or "N", but not "D" Gabe TJ Wrangler Technical Forum 4 02-27-2010 06:09 PM
mettalic "clank", "pop", "squeak" txpedro TJ Wrangler Technical Forum 2 03-21-2007 05:45 PM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty TJ Wrangler Technical Forum 4 04-03-2004 01:24 PM
