2'' BB and 1'' BL - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2'' BB and 1'' BL
NOTCH CUSTOMS - Max Clearance Fender FlaresIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineROCKRIDGE 4WD Supports our Service Members! Military Disc
Unread 06-28-2011, 04:41 PM   #1
Jt_grooms
2'' BB and 1'' BL
I have a 3'' BL on now with 33/12.50/15 but I want to replace it with a 2'' BB and 1'' BL. Can I still run 33's with this set up? Is this a good idea or not any suggestions?
BamaJeep828
Jt_grooms is offline   Reply With Quote
Unread 06-28-2011, 06:19 PM   #2
liftedon37s
I basically have that set up and it has plenty of clearance for the 33's.
[FONT="Courier New"]It has some things done to it.[/FONT]
liftedon37s is offline   Reply With Quote
Unread 06-28-2011, 06:36 PM   #3
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Yes, that will work fine.
2004 Black TJ Rubicon - 3" BDS lift, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - Dead stock and puny with 220k miles
MAMMOTH is offline   Reply With Quote
Unread 06-28-2011, 06:52 PM   #4
Jt_grooms
What about flexing do the tires scrub? What kind of lift is yours
BamaJeep828
Unread 06-28-2011, 06:54 PM   #5
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Guy I wheel with runs that setup and doesn't have any issues.
Just make sure the bumpstops are right for it.
Unread 06-28-2011, 07:11 PM   #6
jeepinmichguy_
No longer a Jerk....
jeepinmichguy_'s Avatar
Bumpstop it correctly and you will not rub.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
Special thanks to the following vendors for supporting the TJ of the Month contest:
jeepinmichguy_ is offline   Reply With Quote
Unread 06-28-2011, 07:14 PM   #7
Jt_grooms
Which BB should I go with?
BamaJeep828
Unread 06-28-2011, 08:13 PM   #8
SecondTJ
I have a RE BB and it's really 1.75" after it settled.
I think rocky mountain had a true 2.25" BB
'00 Sport. 5-speed, Detroit TrueTrac Dana 44 rear, Detroit TrueTrac front, 4.10's, 2" RE BB, OME shocks, 31" BFG MT, JKS Quicker Disco's, Borla
'99 Z28 M6, some goodies
'94 'Vette, A4 all stock
SecondTJ is offline   Reply With Quote
Unread 06-28-2011, 08:34 PM   #9
Jt_grooms
I'll take a look at that one. What about the Zone BB
BamaJeep828
Unread 06-28-2011, 08:39 PM   #10
2003X
I ran that set up for a while with 33s. No issues.
2003X is offline   Reply With Quote
Unread 06-29-2011, 05:02 AM   #11
Jt_grooms
Nice jeep what kind of BB is that?
BamaJeep828
Unread 06-29-2011, 05:07 AM   #12
lax22
same setup i have now on my TJ with 33's you'll be good.
Current Jeeps
99 TJ
lax22 is offline   Reply With Quote
