2.5L TJ surged and died. No spark. Help please. - JeepForum.com
post #1 of 3 Old 07-23-2011, 09:39 PM Thread Starter
256ChiliPepper
Here's the story, little long, but questions are at the end.
Friday night I was cruising home in my 2.5L TJ 2200rpms, and 5th gear. My jeep surged down to 1800rpms and jumped back to 2200rpms. I pulled up to the light to turn left a couple hundred yards away and as i eased the clutch out to get going again it died. I thought I had stalled it, but it wouldn't start. It would crank and crank and crank, but wouldn't start up. I ended up having my neighbor tow me home with his jeep. We scratched our heads and tried a couple of things, but it still wouldn't start and we were stumped.
We scanned the computer for check engine codes we found a code for the ignition coil, coolant temperature sensor, and IAC valve (Sorry i didn't write down the codes as it was about 1am and i wasn't thinking) We also had my usual small evap leak and post cat O2 sensor codes that i have been driving with for 6+ months and never had a problem.
Now this morning I started going through stuff, checking everything, and changing some parts. I am getting fuel so it is not my fuel pump. Im not getting a spark so i started to check associated parts. Plugs, wires, cap, rotor, distributor are all only 2 years old but i checked them and they are all fine. I changed the ignition coil, pickup coil, and crankshaft position sensor, and it still isn't get a spark.
What sensors pull the spark if they aren't working right? Does the IAC valve and coolant temperature sensor prevent it from starting?Am I missing something? Could it be the computer?
All opinions are welcome. Thank you in advance.
256ChiliPepper is offline
post #2 of 3 Old 07-24-2011, 09:37 AM Thread Starter
256ChiliPepper
Bump for some help. Ill have to drive a mini van till i get it fixed.
post #3 of 3 Old 07-24-2011, 04:22 PM Thread Starter
256ChiliPepper
I figured it out, F21 fuse in the PDC was blown. I guess i should have checked them better.
2.5l , no spark
No spark during crank but spark when key released...WTF? USMC_JeepGuy YJ Wrangler Technical Forum 16 08-03-2013 09:00 PM
Spark in 3 &4, intermittent in 1&6, no spark in 2&5 LeeTheDestroyer YJ Wrangler Technical Forum 3 05-11-2011 09:20 PM
'92 4.0 just died, no spark not cps garym31 YJ Wrangler Technical Forum 8 02-06-2011 11:55 AM
Jeep Died, no spark, Could be CKP? jasonamorris TJ Wrangler Technical Forum 8 07-05-2010 01:39 PM
Motor died, no spark outlaw67 TJ Wrangler Technical Forum 1 01-02-2010 09:37 AM
