2.5L Ticking - JeepForum.com
post #1 of 3 Old 05-08-2010, 05:42 PM Thread Starter
Stoked99
2.5L Ticking
Just started today - I start it up and there is a ticking sound coming from what seems like the lower back of the engine or the transmission. The noise stops after the engine warms up too. My dad thinks it may be a bad lifter, but if that were the case I think it would be idling rough. Did a few searches and found what some people think is a loose exhaust manifold bolt or a piston about to blow. Any other ideas on what it could be?
Vice President - Low Output 4 Cylinder Jeep Club
'98 2.5L - RC 2.5 - 33's - Beach Cruiser
"Aerodynamics are for people who can't build engines" - Enzo Ferrari
Stoked99 is offline
post #2 of 3 Old 05-08-2010, 07:10 PM
Finsup
yeah mine ticks as well, sounds like a tractor when i first drive off. In my case it is a missing broken manifold stud. specifically the rear most one (closest to the fire wall). with it running i can feel the exhaust lightly puffing out there. hope this helps.
Oh No....a drug dealer is here!
Low Output 4 Cylinder Jeep Club #453
Finsup is offline
post #3 of 3 Old 05-08-2010, 07:14 PM
littledevilTJ
check and make sure all your bolts holding the exhaust manifold are there and tight. i had the same issue and it was the very last bolt holding the exhaust manifold on, it busted off and was leaking.
My OLD build thread:
Florida Specific Forum
littledevilTJ is offline
Another 2.5L Ticking MJB1 YJ Wrangler Technical Forum 5 04-18-2010 12:01 PM
4.2 ticking blue89wrangler YJ Wrangler Technical Forum 15 03-04-2010 03:43 PM
93 YJ Ticking Bad NamesMUD YJ Wrangler Technical Forum 22 02-19-2007 09:24 PM
Ticking yarosig YJ Wrangler Technical Forum 8 02-11-2007 11:54 PM
Ticking Twig TJ Wrangler Technical Forum 2 10-22-2006 04:18 PM
