2.5L Rough idle - JeepForum.com
post #1 of 11 Old 10-10-2011, 09:28 PM Thread Starter
chadrenner69
2.5L Rough idle
my 1997 wrangler se (automatic) today just started running very rough at a stop light, then as i was going under 30 to go park it would sputter and not let me accelerate ver much. After that i go to drive home and it does the same thing while i was going 45 mph. Then i get home to my apt. and as soon as i stop the rpms drop all the way until the engine was shaking violently so i shut it off. While looking under the engine i saw coolant spewed on the top of the fan shroud. The only thing done to this jeep is no ac and catback ehaust. Where should i even start looking for the problem at?
here is a video i just got of my jeep dying, maybe its the 02 sensors? its not trowing a check engine light at all?
chadrenner69 is offline
post #2 of 11 Old 10-10-2011, 09:31 PM Thread Starter
chadrenner69
I also noticed the rpms never stay in the same spot if this also helps
post #3 of 11 Old 10-10-2011, 09:53 PM
Cuder
Welcome to JF.
When is the last time you did a tune-up?
My Build Thread:
Cuder is offline
post #4 of 11 Old 10-10-2011, 11:04 PM Thread Starter
chadrenner69
Thanks! I actually just got it about a month ago and am not sure when the last tune up was
I had planned on doing plugs, wires, cap, and rotor as soon as i get a chance. Should I look into getting authing else for it when i do that?
post #5 of 11 Old 10-11-2011, 01:26 AM
oakmckinley
First I would resolve the failed radiator hose/hoses, if it even was a hose and not a hole in the radiator itself.
That coolant spraying all over could have caused all the other problems.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #6 of 11 Old 10-11-2011, 08:59 AM Thread Starter
chadrenner69
yeah thats what i was thinking at first, im going to get it checked out tomorrow because I cant spot where the leak is coming from
post #7 of 11 Old 10-11-2011, 09:09 AM
Cuder
Look at the back/bottom of your water pump for leakage. It will drip out if the water pump is going bad. It's not that hard to replace. Then I would do a tune up and clean your throttle body and IAC.
My Build Thread:
Cuder is offline
post #8 of 11 Old 10-11-2011, 09:23 AM Thread Starter
chadrenner69
just checked there and it looks like its either coming from the radiator cap or the hose on the top, ho[efully its not a cracked radiator
post #9 of 11 Old 10-11-2011, 04:50 PM Thread Starter
chadrenner69
just edited main post with video of it stalling, what could have happened that just suddenly screwed up my jeep within the past 2 days
post #10 of 11 Old 10-11-2011, 05:03 PM
Line58
The hose by the cap if overflow, I wouldn't expect it to be very high pressure (could be wrong). How do your operating temperatures look? Are you running hot? How do your coolant and engine oil look? Any fluids dripping from anywhere except for up front?
Line58 is offline
post #11 of 11 Old 10-11-2011, 05:40 PM Thread Starter
chadrenner69
everything is good everywhere else, runs normal temp (around 200), no leaks except around the radiator cap
rough idle idle issue rescue913 YJ Wrangler Technical Forum 1 10-21-2010 07:57 PM
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 07:40 AM
4.0L has a rough idle Cobra Jeep YJ Wrangler Technical Forum 0 08-30-2005 07:11 PM
Rough Idle mwitt YJ Wrangler Technical Forum 3 08-19-2005 10:45 PM
Carter BBD fix for No Idle or Rough Idle ScotZ YJ Wrangler Technical Forum 0 03-26-2003 10:26 PM
