2.5L idles high after installing body lift - JeepForum.com
post #1 of 2 Old 08-03-2010, 07:36 PM Thread Starter
TellicoTJ
I just got done installing a RC 1.25" body lift on my TJ, also have a 1" MML but not going to be able to get to it tonight.
Anyway, I cranked it up after the lift was done to take a trip down the road and as soon as it cranked, it stayed at 1500-1550rpm. It usually idles at 750-800rpm.
What could make it idle so high after installing a body lift?
2.5 Liter club memer #169-Red Jeep Club meber #491
Originally posted by: Jeremy93yj To coax out the poop, try rocking back and forth. If that doesn't work, try rocking side to side. Hold your cheeks apart with your hands while you push and scream at the top of your lungs. I also like to put my feet up on the wall and push against the toilet. Another way is to sit on the pot, reach down and grip the bowl with both hands, and push against the floor with your feet.
TellicoTJ is offline
post #2 of 2 Old 08-03-2010, 08:23 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You probably pulled a vacuum line loose when doing the body lift.
Check for loose hoses or any open barb fittings on the intake manifold.
Wheelin98TJ is offline
body lift , bl , rc , rough country , rough idle , tj , wrangler
Installing Body Lift SugarBear TJ Wrangler Technical Forum 7 03-07-2010 12:04 PM
Installing body lift, Cant get the front body mount off... swsscb TJ Wrangler Technical Forum 3 11-07-2008 09:23 PM
mml first or body lift first when installing? rosshh TJ Wrangler Technical Forum 6 06-16-2006 06:52 PM
Installing a 1.25 Body Lift - Tylenol7 TJ Wrangler Technical Forum 5 05-11-2004 06:28 PM
Installing body lift on a 94 YJ bonehead99 YJ Wrangler Technical Forum 6 09-26-2001 06:21 AM
