#1 | |
2.5L 4 cyl. to LS1 V8 Conversion + TJ Build-up
"EDIT" To be more descriptive, this is a 1997 2.5 4cyl TJ to LS1 V8 swap. + Complete TJ Buildup.
The first few pages of this thread are just ideas that were being thrown around before this became a reality starting around page 4 or 5. Hello all, brand new to the forums here. Relly enjoy the site and people from what i've been reading. Im a first time Jeeper, and recently purchased a 1997 TJ Wrangler, 2.5, manual trans. I've had the jeep for about two months now, and relly RELLY want to ditch the 4 banger. I have a 1991 Chevy Z71 sitting around, and would like to swap as much as possible from it into the jeep. I have been doing searches on the site and educating myself on whats involved and how much money this conversion is going to cost. If anything, there may be some great conversion threads I may have overlooked, if you would be so kind to paste in a few links to these threads or websites it would be greatly appreciated. Here's what I think I am in for off the top of my head, your additions will be greatly appreciated also. Things I need: I have the 1991 Chevy Z71, I am going to use the 350 engine, and automatic trans, which I belive is a 4L-60 but I need to double check that. And also all the wiring and computer. Would it be worth bothering trying to use the front or rear axles from the Z71? I am guessing not, but Im a total newb. Are either drive shafts from the z71 or stock jeep salvageable thru modification for the swap? aside from the stuff I can pull off the z71, I know I will need -exhaust system -new radiator but other than that can't think of anything off the top of my head. Im planning on only spending 1500 on this swap, but realistically it will probably total 3000. I would like to keep this thread as my "Build" thread as long as I can get some of you to help me out with tips and such throughout my journey to v8 goodness. Thanks a ton for any information or help!!! -Paul
#2 |
Junior Member
If you were nice on the pedal, you could get by. BUT--
I would look on CL for an old blazer. Swap the tcase, axles, etc. You will need to weld i'm sure to link the steering, and it will take alot of custom work-but will be a beast when you are done! |
#3 |
a v8 would be sweet but have you every thought about a 4.7l stroker they can make about 300 hp and there isnt really any fab work needed and if you brake something you can go to the local napa and pick up the part instead of having to order or make the part.
#4 |
^I'm assuming he wants to do the 350 from the Z71 because he has it already. If you don't mind spending money on a motor swap, a stroker would be a better choice then the old 350 IMHO. The TBI 350's only made roughly 210-220 Hp. A simple stroker will get you to 260 hp. It'd make it easier to pass inspection (although I don't know how it is where you live), maintain OEM reliability, and less complicated when you have to work on it (as in getting parts, diagnosing problems etc.).
I also noticed you're running 33's on stock gears. You can regear for a lot less then a motor swap, that should bring back the performance. 33's on stock gears w/ a 4 cyl. is terrible. I can see why you want more power, but you will see a huge improvement if you just re-gear.
2005 LJ- Mostly stock/ DD 2000 TJ- Slowly Rebuilding 1976 CJ7- 304/TH400 | 3" suspension | Warn 9.5ti | |
#5 |
I relly know nothing about the 4.7 liter stroker at all, this does seem like something I would possibly be interested in. Do you have any other info? is the 4.7 a gm motor? Mopar? v6 or v8? Thanks for your advice!
#6 |
Its the 4.0 stroked to 4.7.
#7 | |
when I first got the jeep, with the 33" swampers. I couldnt even maintain 65 mph in overdrive (5 speed manual trans). but I could keep it at 65mph in 4th gear running about 3100rpms. I have since downsized the tires for everyday driving, and now can maintain 70mph on flat roads at around 2900rpms, it will slow down quite a bit going up hill anywhere from 65mph, and even 60 on the steeper incline highway hills. That is the most annoying, plus there is zero passing power. I still have the 33's and will throw them on for days when I will be off-roading, but the kill me for everyday drivers to work, not to mention the rubber wont last long on the swampers on the highway. I am very interested to hear more about the 4.7 stroker, but like you said, ya I have the z71 trans,motor, electrical and whatever else I can use off it for free right now. Not sure what road to go down. Thanks for helping a fellow Jeeper out man! |
#8 |
That V8 is only rated at 210hp, so you may want to consider other options if you are looking for power. If you truck is a half ton it will most likely have a 700R4, the 4l60E was introduced in 91 for 3/4 ton and up. Also, unless someone did a solid axle swap on your truck you probably don't want to use the front drive line because it is an IFS truck. The rear 10 bolt probably isn't worth the swap effort.
1997 TJ with 4.5 Rubicon Express lift, Warn winch, sliders, 8.8, 5.7L LS1 V8, MTI X1 cam, long tube headers, tune, and a 4L60E. |
#9 |
Oh and most importantly check your swap laws, they may require the donor vehicle to be the same year or newer.
#10 | |
is it true, that the 700r4 is not desirable in our jeeps? I seem to remember everyone recomending the 4l60 Man, having the free truck with the v8 is starting to sound like its not worth the effort to swap into the jeep. Kind of a shame to because it runs real good....hmmmmmmmmm Stil thinkin about it though, I can still rebuild the 350 and get her to 300hp, without an insane amount of cash... |
#11 |
I have been researching a Gen3 v8 swap myself. I compiled a bunch of build threads and info here:
http://www.jeepforum.com/forum/f9/chev-gen3-engine-swap-info-compilation-677831/ That might give you a better idea as to what you're up against. |
#12 | |
#13 |
Junior Member
#14 |
Well - a stroker may be a good option for someone that HAS a 4.0 - it would be just as difficult for him to swap to a 4.0 stroker off the 2.5 as to put in a v8 of some sort....
I will tell you the right way to accomplish this - unless you want to swap engines for the sheer enjoyment of it. If the goal is to stay in the $1500-$3000 budget and get your jeep functioning better on the roads with 33s - sell your jeep as is - and sell the truck - and buy a wrangler with a 4.0 in it.... then with all the extra cash and time you have - swap out the gears for 4.56s - throw on your 33s - and enjoy! You may not want to hear that - and its not as glamorous as an engine swap.... but - that is absolutely going to be the most economical way to get you where you want to be - and with the least amount of work, sweat and effort.... I had a TJ with a 4.0.... and was looking at upgrading the stock axles for about $2500 total with gears, lockers, super35, etc..... i ended up selling my TJ for 16,500 and buying an Unlimited Rubicon for $17,500. Not only did i get the lockers, heavy duty axles, 4:1 TC - I got an extra foot of room in the Jeep. Trust me on this - if your goals are really what you say they are - find a 4.0 with a dana 44 rear TJ, sell the other two vehicles as is - and go jeeping....
Todd Thorson 2005 Yellow Unlimited Rubicon 4" front springs, Caprice Wagon CC623 (3.5") rear springs, BL, BMML, Rokmen TT, SJ Hydros Yellow Jeep Club Member #4 http://www.toddsplace.com |
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
