2.5L to 4.0L - JeepForum.com
post #1 of 3 Old 07-24-2010, 06:03 PM Thread Starter
Joeggernaut
2.5L to 4.0L
Im thinking about buying a 1998 se. the body has 170k but the engine has 106k so the owner claims. I know the se only came with a 2.5L but it now has a 4.0L.
Also do se models have ac because this one does.
Anything I should specifically look for to make sure the swap was done right in regards to engine, tranny, axles?
Also if you know the compression in psi of the cylinders that be great for a standard 1998 4.0L
How do i tell which transmission it has? it could be ax5 or 15 any code on tranny that would tell me?
Joeggernaut is offline
post #2 of 3 Old 07-24-2010, 06:47 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Check the motor mounts and how well they were installed. Look at the placement and make sure nothing looks strange. Check the welds.
The tranny can not be an AX-5 because that tranny does not bolt up to the 4.0.
I would check the wiring harness really well. Make sure it is not hacked together.
Compression should be 120-150 PSI.
Wheelin98TJ is offline
post #3 of 3 Old 07-24-2010, 06:51 PM
wushaw
Rockin jeep
wushaw's Avatar
130-150 on the compression. Look at this place for picts on the trannys The AX15 Transmission - Novak Conversions
Is the exhaust manifold a two piece or one piece, two piece is 2000 and up.
wushaw is offline
motor swap , engine swap , inspection
