2.5 will crank wont start - JeepForum.com
post #1 of 3 Old 04-13-2009, 07:01 AM Thread Starter
JEEP9783
Ok all started yesterday passing an old man that was doing 45 in a 55...apon cutting back in front of him jeep dyed i got the horn and the finger as he passed back by....checked the pdc found fuse f6 under the hood blown...did some reshearch found that fuse is the auto shutdown relay fuse...green 30a...replaced fuse swapped the auto shutdown relay with the horn relay fuse nothing....disconnected the coil at the coil (two pin plug that plugs into coil) replaced fuse and tryed cranking still blowing the fuse....now i am lost...blows fuse everytime i crank jeep....
97tj 2.5l softtop 5spd 175k
thanks for any help as my jeep is on the side of the road right now
chris
JEEP9783 is offline
post #2 of 3 Old 04-13-2009, 07:31 AM Thread Starter
JEEP9783
ANY TECHS OUT THERE? Or others that have had this problem?
JEEP9783 is offline
post #3 of 3 Old 04-13-2009, 10:59 AM Thread Starter
JEEP9783
from my schematic reading it appears that fuse f6 is directly linked to batt power that sends power to auto shutdown relay that feeds the powertrain control module trying to fig what would blow the fuse though
JEEP9783 is offline
HELP!!4.0 will crank but wont (start)! only on second try staralfur TJ Wrangler Technical Forum 12 07-14-2013 10:00 AM
97 TJ wont start 1st crank! jeffro35 TJ Wrangler Technical Forum 12 02-09-2010 02:33 PM
2.5 will crank wont start Greatdane2002 TJ Wrangler Technical Forum 2 12-19-2009 07:33 PM
2.5 will crank but wont start RockHill YJ Wrangler Technical Forum 0 06-22-2009 12:41 PM
4.0 wont start or crank Teddy TJ Wrangler Technical Forum 2 03-10-2009 11:41 AM
