#1 | |
2.5 TJ flat spot at 2000 rpm
As title suggests, My TJ has developed a problem that always seems to happen at 2000 rpm, usually in 4th gear on a gentle incline. It's almost as it the engine bogs down, kind of a flat spot which can be driven through with a bit of a judder. I have replaced the spark plugs, plug leads, rotor arm, dizzy cap all with mopar stuff. Also replaced the air filter with a K&N which seems to reduced the problem slightly (could it be overfueling?)
There are no warning lights and no engine codes to give me a clue so any thoughts apreciated. Cheers, Graham.
Jeep Wrangler TJ 2.5 Millennium Edition |
#2 | |
Check out this thread
http://www.jeepforum.com/forum/f9/2-5l-sputters-2000-rpms-537261/index2.html
1999 TJ Wrangler, 4 banger 5-spd Soft-top, full doors 31" BFG AT, 3" Lift 1954 CJ3B Willys Hurricane 4, 3-spd with Warn Overdrive, Snow-plow NGJC# 15 Low Output 4 cylinder Jeep Club Member #166 Build Thread Are You An Offroad Junkie Quote:
#3 |
Thankyou...Sounds like it may be the o2 sensor(s) then. What i'm not sure about is that the problem seems to be intermittent. I can't make the jeep do it. Could an o2 sensor cause this?
I was thinking maybe an EGR valve problem....What is so special about 2000rpm?
#4 |
Exact same problem here. I've had the Jeep for 4.5 years and 32,000 miles and it just started a couple months ago. I had a downstream o2 go out a few years ago that I never replaced though.
#5 |
You need one of these:
#6 |
So that's what it needs! Does that come with a part number??
I bet jeep dealers stock them for something too
#7 | |
Don't be hatin on us 4 bangers , our jeeps have feelings to ![]()
#8 |
NO worries.
I have one for mine too... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
