2.5 Timing Advance - JeepForum.com
post #1 of 2 Old 09-03-2003, 02:09 PM Thread Starter
MJDan
2.5 Timing Advance
When the rotor is exactly under the #1 post in the distibutor, how many degrees advance does the main crank read on a 2.5 liter engine?
This is the same question I asked yesterday but only slightly different wording. Thanks for all the feedback so far!
Dan
MJDan is offline
post #2 of 2 Old 09-03-2003, 10:07 PM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Dan
I'm not sure where your going with the question, but I can give you some info to help form a better one.
The timing is physically not adjustable, even though the housing has some minor movement when loose, it's recommended to keep it aligned. Distributor shaft alignment is done through a series of steps using TDC and alignment holes. Because of the gear driven set-up, there can actually be 16 positions, only 1 will work, and the plastic bit on the bottom makes it miserable to do.
The computer handles all timing/advance issues through pre-programed maps.
Typically, it'll run anywhere from 5 - 45 degs. At idle, you can expect around 12, it fluctuates alot. If you want an exact number, I can tell you tomorrow.
K9Jeep
K9JEEP is offline
i need to advance my timing bigorangeyj YJ Wrangler Technical Forum 0 01-04-2010 11:09 AM
Timing Advance for more horsepower ? HogHillbilly JK Wrangler Technical Forum 2 02-23-2007 06:12 PM
2.5 Timing Advance MJDan YJ Wrangler Technical Forum 3 11-01-2003 06:35 PM
timing advance bigblack95 YJ Wrangler Technical Forum 6 12-11-2002 12:09 PM
Timing advance??? Old_man_emu TJ Wrangler Technical Forum 7 09-13-2002 12:06 AM
