2.5 with ticking noise - JeepForum.com
post #1 of 41 Old 11-18-2009, 09:26 AM Thread Starter
jakes98
my 98 has 107,000 on its 2.5 4cyl. Had this ticking noise start the other day outa the blue, sounds like its coming from under the valve cover and ticks all the time whether engine is cold or warm. the sound speed up as u accelarate. i put synthectic oil in it and no help. anyone got any suggestions.
jakes98 is offline
post #2 of 41 Old 11-18-2009, 10:18 AM
Racincowboy
I would put my money on a loose rocker arm. Have you run the valves?
99 TJ 2.5" OME lift, 1" body lift, Poison spyder tube fenders yada yada yada too much more to list.
Check us out at
Racincowboy is offline
post #3 of 41 Old 11-18-2009, 10:35 AM Thread Starter
jakes98
i took the valve cover off and everything seemed to be tight and the springs looked good
jakes98 is offline
post #4 of 41 Old 11-18-2009, 01:54 PM
Racincowboy
Did you actually use feeler gauges and check the distance between the valve and rocker. It could also be a bad lifter. That is what I would venture without hearing it.
Check us out at
post #5 of 41 Old 11-18-2009, 02:05 PM Thread Starter
jakes98
that seems to be what everyone i ask thinks so i went and bought lifters today...let ya know tommorow if i wasted 50 bucks or not..thnks guys
jakes98 is offline
post #6 of 41 Old 11-18-2009, 02:06 PM
mdm
Farm Wheeler
With hydraulic lifters how much gap would you say is acceptable?
Jake - how loud is it?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #7 of 41 Old 11-18-2009, 02:07 PM
brucem
I would say you wasted about $44, CRAFTSMAN
brucem is offline
post #8 of 41 Old 11-18-2009, 02:13 PM
mdm
Farm Wheeler
Where would you suggest he find the acceptable gap range?
mdm is offline
post #9 of 41 Old 11-18-2009, 05:21 PM Thread Starter
jakes98
its pretty loud i mean very noticable..did not put lifters in talk to a mechanic he couldnt pin point promblem but said if it wasnt skipping or missing he didnt think it was a lifter and he third one to tell me that...bruce only thing u said was that i waisted 44$ what would you say it is
jakes98 is offline
post #10 of 41 Old 11-18-2009, 06:41 PM
greggus
My 97 2.5 has a ticking everytime I start it, but it only lasts about 1 minute or so and them stops- how long is the ticking lasting?
1997 Wrangler
Northern Michigan
OlllllllO
greggus is offline
post #11 of 41 Old 11-18-2009, 07:05 PM
brucem
I said you wasted 44 because you over paid for feeler gauges, the link shows a set of craftsmen for much less.
Take take the valve cover off and start it up, if it is in the top end won't be hard to hear/spot which valve or lifter is noisy.
brucem is offline
post #12 of 41 Old 11-18-2009, 08:28 PM
GreenZZ
I think he bought lifters not the feeler gauge.
GreenZZ is offline
post #13 of 41 Old 11-18-2009, 08:54 PM
mall0y
Have you checked your exhaust manifold bolts? Mine have worked themselves loose several times (even lost 2 once).
When they become loose, I would get a light ticking on start-up which would go away once the engine was warm. As soon as I heard it I would pop the hood, crank the loose ones down (usually the two closest to the firewall) and I'd be good for another 2 months.
mall0y is offline
post #14 of 41 Old 11-18-2009, 09:12 PM Thread Starter
jakes98
it ticks constantly even after driving for a while and letting temp. get up but havent lost any oil pressure
jakes98 is offline
post #15 of 41 Old 11-19-2009, 12:21 AM
2000jeeper
Hydrualic lifters dont have a gap at the rocker arm once they are pumped up. Only mechanicals have a gap
AMSOIL DEALER
2000jeeper is offline
Ticking Noise Tradesman300 TJ Wrangler Technical Forum 2 10-09-2009 11:01 AM
Ticking noise xdanielle20007 TJ Wrangler Technical Forum 4 03-09-2009 08:59 PM
Ticking Noise treem06tj TJ Wrangler Technical Forum 6 03-07-2008 08:06 AM
ticking noise zoeconner JK Wrangler Technical Forum 5 01-08-2008 03:37 PM
ticking noise. captain_andrew TJ Wrangler Technical Forum 9 01-09-2005 09:56 AM
