Quantcast 2.5" Rough Country Lift question on 2005 automatic Rubicon - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2.5" Rough Country Lift question on 2005 automatic Rubicon
Old 11-25-2008, 10:39 PM   #1
zx5go
Ok, I ordered the 2.5" RC lift and front stabilizer. I've received it and read the installation instructions. I'm looking for anyone that has a setup like mine and can shed some light on things. I have the JKS BL and MML and I'm wondering (actually assuming but I want confirmation) if this means I'll likely be able to get by without the transfer case drop. Also, anyone with the automatic 03-06 that can say whether or not they have the issue with the driveshaft contacting the transmission skid at full droop? Did you remove? If I have this issue my plan is to mark the skid plate and trim it.
Desire is irrelevant.
A grateful nation never forgets.
zx5go is offline   Reply With Quote
Old 11-25-2008, 11:38 PM   #2
mudb8
want it rite or rite now?
mudb8's Avatar
won't need the t-case drop as you're assuming... the rubi has a long enough shaft to run without it.
you'll need to cutt off the driver's side frame mount with the sawsall and leave the tranny skid in place. it'll flex some but won't let ya punch a hole in the pan. mines been bashed many times, still hasn't bent the pan. I had always planned to rebrace it tho never got around to it. been like this since 03
as you can see....
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 11-26-2008, 08:54 AM   #3
RCXTREME
Vendor
RCXTREME's Avatar
Everyone I have talked to with the Rubicon has not had to drop the t case. I think you will be fine.
Call me (Jeffery) for any Rough Country lift kit issues or purchases on your lift kit. All jeepforum.com members will recieve 10% off when purchasing through me. 1-800-222-7023 ext 125
Youtube channel
http://www.youtube.com/user/RoughCountryTV?feature=mhee
RCXTREME is offline   Reply With Quote
Glock Forum
