2.5 liter speed ?. Cruise speed 33'12.5"
| Spartan Lockers FREE SHIPPING Excellent Prices | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | Mojave Cut & Fold Rear Bumper – Jeep Cherokee XJ |
#1 | |
What Speed should I be able to cruise comfortably at. Tires are BFG Mudterrain,33x12.5. Gears are 4.53's. Miles on rig is 73k. Hardtop. Mine doesn't want to go much over 65 mph. I am wondering if my Cat is clogged. Thanks guys. Joe
#2 |
i got 32 x 11.5 tires on my 2.5 litter and 65mph is my top speed. I mean, ive gotten almost to 80 before. I can consistenly get up to 60- 65mph on the highway. 55 mph with alot of wind nad pushing the gas. On a long trip i'll eventually pick up to 70-75. Its the dam wind that gives slows me down. If im behind another car thats breaking the wind, i can stay on his *** at like 60-65 mph. But if my Jeep is the one breaking the wind, ill slow to like 50-55 and every car behind me will eventaully pass.
99 TJ. 5 sp Manual. 4 cylinder. 2.5 liters. airaid intake.
Rock Guards. 32x11.50r15. 4 inch lift. nitro Shocks. |
#3 |
I have a 4banger with 4.56 gears and 32's cooper stt. I can travel between 70 - 80 and very often 85-90. My 265/75/16 tires are between 32's and 33's but the are only 10.5 wide and I think that helps a lot.
EDIT: I have the 5gears manual, i think that helps a bit.
2000 tj 2.5l 4.56 dana 30 aussie locker /super35 ARB, 35s maxxis crawlers, RE3.5sf, RE monotubes, 1"BL, currie anti-rock, currie steering, or-fab cage,ARB bull bar, warn m8000
#4 | |
#5 | |
#6 |
have anything that sounds like and exhaust leak? That seems to sap the power on my 2.5 everytime it happens. Done a tune up? replace your plugs with good quality chamions (no platinum's they make it worse).
2002 Jeep TJ SE 2.5L Sienna Pearl, dual tops, tan interior, 31x10.5's, 1" Rubi Spring lift (yes it does boost an SE 1", ask me how I know) Work 2 Live, Live 2 Play, Play = JEEP |
#7 |
Thanks To all
Thanks for the help. Any one else got any suggestions? Joe
#8 |
on 33 12:50 trxus with 5:13 gears, can hit 70-85 without issues.I'am also running a cam and a 4.0 tb.Prior to these mods i was running same tires with 4:88 gears and an all stock engine.I still was able to cruise at 70 most of the time except on some of the stepper hills around here.Even then i'd still hold 65.If you're geared right and the engine is in good tune you should'nt have a problem holding highway speeds if you are driving it right.By that i mean having it in the right gear.Crusing At highway speeds you should be in the 2750 to 3500 rpm range,below that and your lugging it something a 4banger is not good at.
Join metro wars it's fun & addicting [URL="join metro wars it's fun and addicting"]http://metrowars.com/register.php?REF=31522 [/URL] |
#9 | |
I have an 03 tj se with the 2.4L. I hear a hissing sound btwn 2500 and 3100 RPM in third and sometimes second gear. Haven't noticed it in first, fourth or fifth. It doesn't seem to lack power in that range, but I definitely noticed the sound. What should I look for? I haven't really examined the manifold. I suppose that is a good place to start.... |
#10 |
2.5L/4.88/33x12.5" MT's/Manual transmission
I can get to 80, but it doesn't like it too much. 70-75 is about the most it will do. Top on REALLY helps on the highway vs no top or doors.
-Paul Green Jeep Member #155 Low Output 4 Cylinder Jeep Member #35 Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it. |
#11 |
yeah always a noticable difference with top down and/or doors off
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
