2.5 liter power steering/vacuum issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2.5 liter power steering/vacuum issue
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-04-2009, 07:36 AM   #1
RyanEck
I have an 02 TJ that is experiencing a few different issues and I am not sure if they are related. For starters, the power steering seems to be sluggish to get going when I first start out in the morning, but once it is going it is fine. This is coupled with the defroster and vents shooting out air no matter what the setting is. I know the defroster issue is probably a vacuum leak, though I can't find one. I was just wondering if these two could be related and if there is a certain area under the hood I should be checking. Any help would be greatly appreciated.
Ryan
RyanEck is offline   Reply With Quote
Unread 06-04-2009, 09:58 AM   #2
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
for help.
TheBoogieman is offline   Reply With Quote
Unread 06-04-2009, 01:59 PM   #3
RyanEck
bump again for help.
Unread 06-04-2009, 02:06 PM   #4
RYANSTULC
Those 2 issues aren't related.
You're probably right about the defroster vents always blowing air.
The power steering issue might be as simple as being low on power steering fluid, although doubtful.
RYANSTULC is offline   Reply With Quote
Unread 06-04-2009, 02:28 PM   #5
RyanEck
Yeah I have checked the fluid levels and it appears to be fine. Afraid the pump may be going. It does seem a tad louder than normal.
