#1 | |
2.5 Life??
What is the life expectancy of a well maintained 2.5 engine?? Just curious. Thanks.
#2 | |
I have a 98 TJ, with 57,000 miles on it.
98 TJ SE Completely Line-Xed |
#3 |
Demonic Jeep Freak!
I had over 200,000 miles on my 2.5 when I sold it to a neighbor.It never smoked or used any oil.He is still driving it 2 years later with no problems.I think it's got about 225,000 miles on it now.
#4 |
The Jeep 2.5 and 4.0 engines are both easy 200K+ engines with regular maintenance.
I have personally driven a friend's 2.5 YJ that had over 300K on the clock, and it ran like new money. Now it had gone through three AX5s in that time.....
2002 TJ SE 2004 WJ Laredo 4.7 2006 LJ 2007 Rockwood Freedom 2280 "...in the GOP, enthusiasm is measured in Reagan units." |
#5 |
The 2.5 will never die... unless you've got a lemon or absolutely abused the thing (but how can you?)...
It's easier to go down a hill than up it but the view is much better at the top. -Henry Ward Beecher Current - '98 Black Z28 with some goodies Previous - '97 Gun Metal Blue TJ Northern Illinois Extreme Jeep Club www.ExtremeJeepClub.com |
#6 |
Ive got 160,000. Has anyone replaced the timing chain or know if there is a recomendation for replacement?
98 TJ 4 cyl 3" FT 33x12.50 Pro Comp's 4:88's ARB's F&R |
#7 |
I've got close to 90K on mine. Runs like a champ. Oil gets changed every 3K. Cap, rotor, plugs and wires when needed. Purrs like a kitten.
02 2.5.L automatic: 4.0L t.b., 4.0l air intake, K&N filter, Scream'n Demon coil, 8.5mm MSD Super Conductor plug wires, Stage 1 Jet Chip, 29" BFG all terrain KO's. Taurus E-fan, Hummer front bumper, Skyjacker high capacity trans pan, 48" hi-lift, Rubi susp, 3/4" Daystar BB. |
#8 | |
#9 | |
#10 |
250,000 new water pump..cracked exhaust manifold ..original alternator and starter
a 2.5 will never die |
#11 |
Thanks for the input guys!! Just bought one today. A`97 TJ 2.5 with the 5 speed. Going to try to find a vin look up to determine the gearing. I got lucky to find this model year in this great of condition!!!
#12 |
4.10 or 4.11 is your gears
Chrome can get you home, you can signal the search aircraft with it! |
#13 |
lemmie save ya some time... 4.10's front and rear, dana 30 front, dana 35 rear, ax5 tranny 21 spline np231 transfercase...
#14 |
Thanks again!!!!
#15 |
Personally, if I was going thru the trouble to regear, I would consider 4.56 front and rear. This way if and when you upgrade to 33" tires, you will be good to go.
I run 33" tires, and 4.56 gears. I am very satisfied with it.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
