2.5 l TJ Rap noise - JeepForum.com
post #1 of 1 Old 08-29-2010, 03:31 PM Thread Starter
JimA
2.5 l TJ Rap noise
Got a TJ 2.5 with about 75k mi. and have a rapping noise which starts about 30 seconds after a startup. Using Mobil 1 10-30. I've replaced the lifters, pushrods and rod bearings, replaced end bolts on the exhaust manifold. The noise hasn't gone away and maybe is a bit louder. Last nite I pulled off the ccv hose to the air box. When I held my thumb over the elbow on the valve cover as the vacuum pull on my thumb increased the rap went away.
When I removed my thumb the rap gradually came back. I flushed the engine with Gunk cleaner and the rap is still there. Any help or ideas would be appreciated.
JimA is offline
Tick noise like lifter noise. jeepdogg305 TJ Wrangler Technical Forum 6 03-24-2010 07:31 AM
loud noise when in reserve , noise when taking sharp right turns??? ReD-RuM TJ Wrangler Technical Forum 5 12-25-2009 09:15 AM
NP231 Noise- I know another noise thread! dmock YJ Wrangler Technical Forum 0 04-17-2009 06:48 PM
Difference between Lifter noise and exhaust noise? CAPCDT388 TJ Wrangler Technical Forum 7 11-10-2008 10:31 PM
Transfer Case Noise/BL Noise rugerj TJ Wrangler Technical Forum 6 12-18-2006 11:26 AM
