2.5 idles low, is it the Idle Air Control or the Throttle Position Sensor....? Both?
| Spartan Lockers FREE SHIPPING Excellent Prices | Black Magic Brakes - 5% Off, No Minimum Purchase Required | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- |
#1 | |
Hi guys... this is my first time posting on here, although I've been reading your posts for a while now. Very helpful and informative!
I have 2001 Wrangler, 4 cyl 2.5L. For a few weeks now, I've had the low/ rough idle problem. It seems to start up fine. I will drive it for a minute or so... as soon as I stop, the idle speed will drop to 400-500rpms.... it will stall out at that point. If I stop but keep giving it gas- the rpms will stay up and things are fine. It will not stall or buck while the throttle is engaged. Only at idle... No check engine light, by the way. I cleaned out the opening to the throttle body and the plate, pretty dirty. Upon the advice of my mechanic- I changed the Crank Sensor. (When the problem started happening, the engine would stall at idle and wouldn't start back up. It'd crank, but no spark.) So I changed out the Crank Sensor and am still having the low idle problem. I read many posts here about cleaning the Idle Air Control. I tried that, but the problem persists. It's intermittent, but seems to happen less after a drive on the freeway. My friend had the exact same symptoms on his 2002 Toyota Tacoma truck. He also tried a few fixes before changing out the TPS. He said that solved the problem and may be the cause of my woes. However, when I looked at the part he bought- it was a TPS with an Idle Air Control attached to it- one single unit! This makes me wonder if my problem lies in the TPS or the Idle Air Control. Is there a way to tell if it's either/or? Cleaning the IAC didn't resolve it, but I couldn't tell if the unit itself was faulty just by looking at it. Money is an issue for the next 10 days and I can only afford to change one of those components today. Should I try one over the other? I'm leaning towards the TPS. Thanks in advance, fellas... I appreciate any help. Brian
#2 |
Running Secretly Amok!
Try pulling the IAC on throttle body first and cleaning it with some throttle body cleaner (cheap) $10.00 under bucks. Sorry re read your post you've already done that.
#3 |
Thanks for the reply!
Yeah, I removed it from the throttle body and cleaned it up two days ago- but it didn't change things. That's why I'm thinking it either needs to be replaced, or the TPS needs to be replaced. |
#4 |
Yea the only bummer is no codes being thrown?
#5 | |
low idle
The iac is what controls the idle speed. The tps just tells the pcm how far open the throttle is. Good luck. Moose |
#6 |
Well dudes... I changed out the Idle Air Control and I think we got a winner! Of course I won't know for sure until I drive it for a couple of days and nothing happens... but so far, so good. I drove to the gas station and the idle speed stayed around 800-900. At a complete stop, it would dip down to about 700.
Is there any kind of reset that I need to do? A "guide" that came with the part mentioned how the idle speed may initially be abnormally high- but that did not happen. I had the battery disconnected when I did the job, it took maybe 30 minutes to complete. Thanks again, guys... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
