2.5 Header Question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2.5 Header Question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitClayton Off Road - Come see us at these events!
Unread 07-16-2012, 07:37 AM   #1
JD37055
2.5 Header Question
Looking to put a header on a 2.5, any suggestions? Seen a pacesetter at a good price, any ideas?
JD37055 is offline   Reply With Quote
Unread 07-16-2012, 07:44 AM   #2
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Stock works as good as any.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
TheBoogieman is offline   Reply With Quote
Unread 07-16-2012, 08:39 AM   #3
jeepster82
My factory one I just put on works fine. I bought my jeep with a cracked manifold and the PO broke 2 bolts off in the head. Cost me 300 bucks to have it fixed. Pb all the bolts before you try to remove them.
87 wrangler on 33s
97 wrangler with RE lift on 31s, locked in the rear
05 turbo busa-381rwhp @ 22lbs of boost
2000 jeep grand 4.7 awd stock wife's dd
jeepster82 is offline   Reply With Quote
Unread 07-16-2012, 09:14 AM   #4
JD37055
Next question. Factory best for sealing or performance?
