2.5 freeze plug help - JeepForum.com
post #1 of 9 Old 04-18-2016, 06:00 PM Thread Starter
Ppratt3
Do believe it's time for some new freeze plugs. I have a bad leak today. I can't find any info on replacing them on a 4 cylinder. I can find the 4.0 how to but not for the 2.5. Can someone help me with a link or any info. I hope I don't have to pull the motor I never changed one before
I would like to, but my wife won't let me.
Ppratt3 is offline
post #2 of 9 Old 04-19-2016, 06:59 AM
prjohnson
From what I understand the 4 cyl is basically the same thing as the six, minus 2 cyl. I found a picture that shows at least four additional I don't recall having when doing mine. http://www.wranglerforum.com/attachm...p;d=1421776220
I don't think you'll have to pull the motor, but on mine, I had to pull the transmission & the head. Where do you think it's leaking from? I wouldn't do it unless I was absolutely sure that's what it was.
prjohnson is offline
post #3 of 9 Old 04-19-2016, 08:14 AM Thread Starter
Ppratt3
It was getting dark. Everything was wet today when I get home. I will start it up and watch it.
Ppratt3 is offline
post #4 of 9 Old 04-19-2016, 10:10 AM
TJ4Jim
If I recall correctly there are 3 plugs at the rear of the engine, one is in the head and 2 are inside the bell housing. Only the plugs under the manifolds are accessible without pulling the engine.
If you come to a fork in the road take it.
TJ4Jim is offline
post #5 of 9 Old 04-19-2016, 11:53 AM Thread Starter
Ppratt3
well it was on the manifold side that was wet.
Ppratt3 is offline
post #6 of 9 Old 04-19-2016, 07:25 PM Thread Starter
Ppratt3
Ok with some daylight left I don't see any bad freeze plugs. The one nearest the wet spot is dry as a bone. I'm now thinking water pump or the gasket it's really wet behind and around the Pullley.
Ppratt3 is offline
post #7 of 9 Old 04-19-2016, 09:49 PM
4byfourbyeIV
Bet you're glad you didn't just drive it to the dealership and said, "Frost plugs are leaking... change them...."
Sent from my SM-T210R using Tapatalk
Funny how some never have time to do it right. But always have time to do it again.
4byfourbyeIV is offline
post #8 of 9 Old 04-20-2016, 04:13 AM Thread Starter
Ppratt3
I would have done the work myself but yes I slept well last night. Worst came to worse I have 400 in credit at the local off road place I could have took it there the sting wouldn't have been that bad.
Ppratt3 is offline
post #9 of 9 Old 04-20-2016, 06:46 PM Thread Starter
Ppratt3
I took the pump off the bearings seem to be shot. Very loud when you spin the impeller and the bottom clamp was rusted in half that clamps the hose to the pump. I'm thinking I will be good to go after I install it tomorrow.
Ppratt3 is offline
