2.5 engine compatibility - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 2.5 engine compatibility
2014 Spartan Locker Special - While Supplies Last! Dana 3The Original 3/8" Ruffstuff Diff Cover!The RuffStuff "I can't go to EJS" Sale!
Unread 03-20-2014, 09:34 AM   #1
Lg5489
Hi I'm from the uk and have a 97 TJ 2.5 which needs a new engine. Would one out of a Cherokee fit straight in or is it only engines from the wrangler that will fit?
Thanks Lewis
Lg5489 is offline   Reply With Quote
Unread 03-30-2014, 06:54 AM   #2
Lg5489
Nobody?
Unread 03-30-2014, 07:26 AM   #3
wwch99tj
Any 2.5 from 87-02 will work
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is online now   Reply With Quote
Unread 03-31-2014, 08:55 AM   #4
Lg5489
Thanks for your help, I thought that they were the same but read a few different things about the Cherokee one being slightly different.
Cheers Lewis
Unread 03-31-2014, 10:38 AM   #5
JStMarie
JStMarie's Avatar
Just curious, how many miles..err kilometers did it have before it went and was there an underlying reason? I have the 2.5L in my '98 and it has 222,000 miles (357,274 kilometers).
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is online now   Reply With Quote
Unread 03-31-2014, 04:27 PM   #6
Lg5489
Not too sure I bought it with no water pump on the engine but it was on the passenger seat and was obvious the bearing had gone so replaced it with a new one ran it up to temp and checked dip stick and low and behold water in the oil
The engine only has 72,000 miles on the clock so really low compared to most, can only assume old pump failed and threw belt which overheated the motor
