2.5 to 4.3 swap - Page 2 - JeepForum.com
post #16 of 23 Old 04-14-2013, 11:04 PM
Mcjeeperson
Wrapped up, bolted to the pallet ready to ship.
Mcjeeperson is offline
post #17 of 23 Old 04-22-2013, 06:22 AM Thread Starter
whitwt
Hello! After a bit of a hiatus that has been filled with :work, honey-do lists and building a green house, I am back at it! My drivetrain will be at a pickup location the weekend. And being that I live in the middle of nowhere it is a 3 hour drive to pick it up. But lucky for me I was going to Des Moines anyway because I good friend will be in town. 2 birds!
So Yesterday I finally hoisted the tub off of the frame. I am doing all of the work at my folks' place. So I built a big *** header in the rafters of my dad's shed (which took longer than anything else yesterday) and hooked up a chain hoist. Rigged it to the roll bars with chains and Boom!, tub in the sky. I missed two giant bolts that were hiding just in front of the gas tank. So we started to actually lift the back end off of the ground. I lowered it and found the bolts. No problems. I only missed one hose! It went from the gas cap area to the top of the rear brakes? No idea what that is. But I disconnected it and no worries.
Below are the pics. This week I finish disconnecting the harness, strip the brake system and exhaust, and then work on that drivetrain! Anybody want to buy an old AX5 and a busted 2.5? I know you do! Then grinding and painting the frame. Then lift kit. Then new drivetrain placement... How do you eat an elephant? One bite at a time.
whitwt is offline
post #18 of 23 Old 05-08-2013, 04:52 PM Thread Starter
whitwt
Sometimes rainy days equal days off when you work construction. Not always a bad thing. I got the frame stripped off completely. The only things still attached are the gas tank and the stock suspension. Maybe tomorrow I will get the tank off and start cleaning and grinding. Any recommendations out there on a product to apply to the newly cleaned frame? My brother raves about POR 15. Any other ideas?
I ordered the suspension and body lift kit from Rough Country. 2.5" suspension/ 1.25" body. I am pretty excited to get that put it in. I have owned the jeep for all of 5 years now, and I have sadly never taken the leap to lift it. Sad, I know... But I may as well do it while I am at it.
I did some reading on other swap threads and am mentally preparing myself to rebuild/frankenstein my 231 transfer case with the 241 that I received from Mcjeeperson. If I understand correctly, I should be able to keep my splines out and just change my splines in. But then does it bolt up the the nv3500 tranny that came with it? Or do i just keep the 241 completely and try to make it fit? Not sure which route to go, I gots some more reading to do. Regardless, it was a productive day.
One more thing. Anyone know where I can sell a dead 2.5 and and old ax5? Maybe I should sell the 231 with it?
whitwt is offline
post #19 of 23 Old 01-03-2014, 08:09 PM
vavision
Any updates? Looking at all options for my 2.5 myself
Mad scientist motorcyclist trapped in a jeepers body... when driving.
vavision is offline
post #20 of 23 Old 01-04-2014, 09:51 AM
rda616
The 4.3 would be a big waste of money. You can have an ls motor for the same cost and the same amount of work. You can have a magnum v8 for less money and less work.
rda616 is offline
post #21 of 23 Old 01-04-2014, 09:53 AM
rebelbowtie
Waste of money? No! Can money be better spent on a Gen III s all block? Absolutely!
rebelbowtie is offline
post #22 of 23 Old 01-04-2014, 09:57 AM
rda616
definitely a waste of money.
rda616 is offline
post #23 of 23 Old 03-11-2014, 09:49 PM
jherrington
Who the hell would want another dodge engine when you could swap in a chevy?
Edit: unless it a hemi
jherrington is offline
2.5l , 4.3 , electrical system , help please , swapping
