2.5-4.0 swap is underway!! - Page 9 - JeepForum.com
post #121 of 172 Old 10-07-2013, 01:36 AM
Dirty_Bird
lol ok here is the pic.. i might just be just over reacting.. none the less want to make sure..
Dirty_Bird is offline
post #122 of 172 Old 10-07-2013, 01:39 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Pic not working?...
Knuckelhead is offline
post #123 of 172 Old 10-07-2013, 01:45 AM
Dirty_Bird
sorry they where too big.. they are there now.. you can see on the third pic from beside the dif theres a few inches difference on the side..
I think im just making something out of nothing lol
post #124 of 172 Old 10-07-2013, 02:04 AM
Knuckelhead
AFSOC Retired
Something is amiss, your transfer case output shouldn't be that far to the passenger side and the case looks to be clocked wrong...
post #125 of 172 Old 10-07-2013, 02:11 AM
Dirty_Bird
Clocked wrong? is it just a possibility that i need to make new holes in the skid plate?
post #126 of 172 Old 10-07-2013, 02:32 AM
Knuckelhead
AFSOC Retired
Yes, clocked wrong.
What motor mounts are you using and do you have the transmission mount bolted to the skid plate?...
post #127 of 172 Old 10-07-2013, 02:37 AM
Dirty_Bird
motor mounts are not in yet. the transmission is not fully bolted but it is with bolts and fully in the holes of the skid plate.
Now the holes are from the skid plate of the 2.5litre so I am not sure if they are the same.. it felt perfect just noticed that after.
post #128 of 172 Old 10-07-2013, 02:42 AM
Dirty_Bird
its possible that the motor is not high enough as well if thats what you meant... its not in its place.. but the angle of the side to side portion of the t case is. that is what I am worried about
post #129 of 172 Old 10-07-2013, 02:54 AM
Knuckelhead
AFSOC Retired
You need to get the motor mounted in place and take another picture...
post #130 of 172 Old 10-07-2013, 07:22 AM Thread Starter
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
You may need to try a different trans mount. Even though the trans and TC are the same the trans mount is different. What one are you using?
Sent from my phone where grammar isn't easy.
RnEmOvr is offline
post #131 of 172 Old 10-07-2013, 11:14 AM
Dirty_Bird
Its the tranny mount from the Its the mount for the skid at the same time..
post #132 of 172 Old 10-07-2013, 11:46 AM
Varnish
Varnish's Avatar
I know the XJ aw4 clocks the tcase differently than in a wrangler, likely the same with an XJ ax15, the wrangler has a flatter clocking setup.
'98 TJ, '06 LJ, '88 YJ, '86 CJ, '99 XJ 4dr Ltd
Varnish is offline
post #133 of 172 Old 10-07-2013, 01:40 PM
Dirty_Bird
thanks guys.. im gonna lift the transmission and see if the mount can be adjusted to the sides..
Ill let you guys know
post #134 of 172 Old 10-07-2013, 11:39 PM
Dirty_Bird
ok so ... i drilled some new holes in the skid plate and it seems to be way better. Now just finish preping the motor mounts.. and then wiring.. hopefully be done by this weekend!
post #135 of 172 Old 10-07-2013, 11:56 PM
Knuckelhead
AFSOC Retired
What PCM are you using with your engine swap?
Fill in your profile...
2.5 , 4.0 , computer , engine , harness , swap , tj , YJ
Frame Repair Underway sentinal02 YJ Wrangler Technical Forum 60 04-11-2016 01:39 AM
The swap is offically underway... leftlanetruckin YJ Wrangler Technical Forum 486 12-31-2014 08:45 PM
Phase 1 underway Schwalby TJ Wrangler Technical Forum 9 02-06-2008 10:35 AM
Swap Underway jwrangler91 YJ Wrangler Technical Forum 1 03-11-2007 09:08 PM
2.5l to 4.0l swap underway. ID89YJ YJ Wrangler Technical Forum 2 12-20-2006 09:44 PM
