2.5-4.0 swap is underway!! - Page 8 - JeepForum.com
post #106 of 173 Old 03-06-2011, 01:17 PM
Offroader239
Thanks 1997 TJ Wrangler,
But im kinda looking for like a more specific measurement.. it looks like about an inch or so forward.
Do you no if i am correct?
Offroader239 is offline
post #107 of 173 Old 03-09-2011, 01:24 AM Thread Starter
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
yes they need to be moved, how far I dont remember. What I did was bolt them to the motor, place it in frame and welded accordingly, just make sure that you leave clearence for the fan and radiator, mine is close to the firewall as possible
Originally Posted by Grewe02 View Post
Shh you. I didn't scroll all the way back.
Nobody will mind if you resurrect an old thread for a legit reason.
I'm quite sure that they do need to be moved. Not positive, but I believe so. Might want to wait for Randy or someone else to comment.
we all know you never read everything LOL
Sorry to all those who asked questions and sent PMs, I wasnt getting the emails. Feel free to email me any questions, my email is my screen name at hotmail
RnEmOvr is offline
post #108 of 173 Old 03-27-2011, 11:06 PM
navy4life
Alright, i've read this from the beginning and i have one question for you since your a pro now. Ive got a 99 TJ with the 2.5, and I want to do this exact swap. I have almost everything, except somebody told me that i would need to swap out the input shaft on my transfer case if I wanted to do this, but to my knowledge the 2.5 and 4.0 came with the same np231 transfer case? any help would be appreciated, also GREAT write up!! definitely helped me out
navy4life is offline
post #109 of 173 Old 03-27-2011, 11:42 PM
Griff97
The 2.5 NP231 uses a 21 spline input. The 4.0 NP231 uses a 23 spline input. As for everything else that I've seen they are exactly the same other than the input shafts.
Griff97 is offline
post #110 of 173 Old 04-05-2011, 12:13 AM Thread Starter
RnEmOvr
RnEmOvr's Avatar
^agreed good call Griff
RnEmOvr is offline
post #111 of 173 Old 04-27-2011, 03:39 AM
MODUS
MODUS's Avatar
my Congrats !!!
we are doing the same right now into a friends tj '99.
i have seen that you used new oem frame mounts and you diy reinforces. nice job
the question is about new frame mounts position? do you remember or someone else who did that swap before how much forward did you weld the new mounts ? need some serious mesurements here ?
waiting from you guys
thanks in advance
TJ '03 SAHARA EDITION
Thanks..
MODUS is offline
post #112 of 173 Old 04-27-2011, 03:32 PM Thread Starter
RnEmOvr
RnEmOvr's Avatar
Originally Posted by MODUS
my Congrats !!!
thanks in advance
I don't have the measurements if you read up a few post you will see how I positioned mine
RnEmOvr is offline
post #113 of 173 Old 03-06-2012, 10:28 AM
R0cket
1930 TJ Wrangler
Resurrection!
Time to resurrect it again...
I got a 2002 TJ, and a 4.0L from a 2006..
Got EVERYTHING to do the swap and I'm into it $1700 total. Probably gonna swap it this weekend.
Awesome write up!!!! Thanks so much.
I'll post some updates as they come..
Ian
AME2 USN, Disabled Vet
R0cket is offline
post #114 of 173 Old 09-09-2012, 11:43 PM
rhovater
same here....in the process of putting in a 4.0 and AW4. so far its the wire harness adn ecu that is the pain in the but. everything so far has not been so bad, and having a father that is a welder helps.
rhovater is offline
post #115 of 173 Old 10-06-2013, 11:37 PM
Dirty_Bird
Ok Im basicly in the ends of this. but... lol I swapped a 99 cherokee 4.0 to my 01 tj. the issue im having is the skid plate. do I have to drill new holes for the tc to align with the yoke of the diff.. because it seems it is not aligned proprely..
Really need some help with this!!
Thanks!
Dirty_Bird is offline
post #116 of 173 Old 10-06-2013, 11:46 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
What transfer case and transmission are you using?
Filling in your profile helps...
Knuckelhead is offline
post #117 of 173 Old 10-07-2013, 12:07 AM
Dirty_Bird
oh sorry.. the ax15 with the 23 splines for the TC.
It camed out of the cherokee and fully going into the tj.. well its there..
also i do have the SYE on the TC. BUT that should not change the alignment of the tranny and TC to the Diff.
Like there is a few inches off for sure. im wondering if IM just paranoid or is this really an issue?
post #118 of 173 Old 10-07-2013, 12:12 AM
Knuckelhead
AFSOC Retired
What exactly is off, I don't understand what you're having an issue with?...
post #119 of 173 Old 10-07-2013, 12:15 AM
Dirty_Bird
ok , if i was to install a drive shaft right now.. there is an angle from left to right and from up to down. so the transfer case is not aligned to the rear dif for the driveshaft. not sure if this is normal but it is more on the passenger side.
does that make more sence?
post #120 of 173 Old 10-07-2013, 12:24 AM
Knuckelhead
AFSOC Retired
Can you post a picture looking at the transfer case from the rear axle?...
2.5 , 4.0 , computer , engine , harness , swap , tj , YJ
rusty_wrangler
Frame Repair Underway sentinal02 YJ Wrangler Technical Forum 60 04-11-2016 12:39 AM
The swap is offically underway... leftlanetruckin YJ Wrangler Technical Forum 486 12-31-2014 07:45 PM
Phase 1 underway Schwalby TJ Wrangler Technical Forum 9 02-06-2008 09:35 AM
Swap Underway jwrangler91 YJ Wrangler Technical Forum 1 03-11-2007 08:08 PM
2.5l to 4.0l swap underway. ID89YJ YJ Wrangler Technical Forum 2 12-20-2006 08:44 PM
