2.5-4.0 swap is underway!! - Page 7 - JeepForum.com
post #91 of 172 Old 12-16-2009, 02:34 PM Thread Starter
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
so your motor is a 91? if so replace the sensors its easier
RnEmOvr is offline
post #92 of 172 Old 12-16-2009, 03:40 PM
H_Swank
Everything is 91 except the motor and tranny. They are out of a 97 TJ
H_Swank is offline
post #93 of 172 Old 01-12-2010, 07:50 PM
2000GrayTJ
Advice for engine to swap into 2000
The time has come to start looking for a powerplant to swap for the 2.5 in my 2000, I know the wiring harness compatability ranges from '97-'99 and '00+ (I think thats what you mentioned). I was just wondering if it had to be an XJ motor would '97-'99 be my only option as they went distributorless in '00. Or does this not matter at all?
Any advice would be greatly appreciated thanks
2000GrayTJ is offline
post #94 of 172 Old 02-17-2010, 08:35 PM
smitty3213
Hey guys love the swap! Im trying to swap my YJ 2.5 to a 4.0...Im assuming I'll also need new motor mounts and factory frame mounts? If so, whats a good way of finding those parts numbers??
Military Jeepers!
smitty3213 is offline
post #95 of 172 Old 02-18-2010, 03:29 AM Thread Starter
RnEmOvr
RnEmOvr's Avatar
going with XJ parts will be about same as mine with sensors needing swaped as well
Military Jeepers!
goto local dealer and tell them that you need the frame side motor mounts for a year X YJ with 4.0 and they can pull them up
RnEmOvr is offline
post #96 of 172 Old 02-19-2010, 05:31 PM
SinCitYJ
86/7 Cherokee to 93 YJ
I have found a dirt cheap 86/7 Cherokee 4.0L that is begging to be swapped. The guy is telling me that its the 4.0 but I am very afraid that it is the 258. Short of the torque upgrade that would make this swap not worth it almost. I have a 93 YJ with the 2.5 and just about everything stock when I bought it minus some 33's and a few inches of shackle lift im trying to get rid of in favor of an SOA. The donor cherokee still runs and everything even after being rolled, leaving the vehicle worthless, to all but us squirrel owners. I am hoping that because I have an entire donor vehicle that this should be an easier swap to do than yours was RnEmOvr. The owner said that it is an 86 with the 4.0 I6, but I was under the impression that the I6 came out in 87 with the YJ's.
So I have rambled on for lines and lines now and I guess I'm just asking for general thoughts on this situation. I realize that the traditional engine swap is to go newer. But the price is so very right on this, and I am getting just about everything that I am going to need all in one. I should be getting pictures coming my way shortly (hopefully of the guts, but I don't know).
So one final update. I have just recently found a couple of other cherokees that are going for a bit more money (about twice as much) but not quite out of the question. and these all definitely have the 4.0L. I'm thinking that the 4.0 is worth the extra 400ish. How about all of you?
Let me know what you all think.
SinCitYJ is offline
post #97 of 172 Old 02-21-2010, 06:55 AM Thread Starter
RnEmOvr
RnEmOvr's Avatar
i would spend the extra $400 and get the better motor as you must also think the roll may have pulled the pin on a ticking time bomb
RnEmOvr is offline
post #98 of 172 Old 04-07-2010, 09:18 PM
2000GrayTJ
Originally Posted by gmbtj View Post
I believe it will. I am putting in a 2000 motor as we speak. But it is necessary for me to use the 2000 harness and ECU too because of the coil change (Luckily mine came with it all). You can do the harness and ECU from the yj, but it will require splicing from hell, and there will be many things (like your gauges and other things) that wont work right because the run off you computer. Best thing to do is get a 97 to 99 harness.
Does anyone know if the ALL 00+ engine/computer/harness can plug into the harness coming from the cab controlling the dash, etc? From what I understand as long as you have the complete engine/computer/engine harness you can swap it whether or not the original year was distributorless or not.
Thanks
post #99 of 172 Old 04-08-2010, 10:41 AM
SjT2107
Just started this swap & appreciate this thread ALOT!!!!
Can't wait to get er dun!
SjT2107 is offline
post #100 of 172 Old 04-11-2010, 08:47 PM
hotwired
I can't believe that I couldn't find this with a search. I'm lookoing at putting a 4.0 out of a 2000 XJ to put into my 97 TJ. Why won't the dash harness work? I've got the motor harness and PCM from the XJ so that's all good, but I really don't want to re-wire the dash.
hotwired is offline
post #101 of 172 Old 04-17-2010, 01:15 PM
SjT2107
Did you have to upgrade your fuel pump??
SjT2107 is offline
post #102 of 172 Old 08-21-2010, 04:47 AM Thread Starter
RnEmOvr
RnEmOvr's Avatar
sorry i missed these. these were posted right when i left
somethign about the connectors are different
no stock fuel pump, have tested and i am right in specs as far as pressure
RnEmOvr is offline
post #103 of 172 Old 03-05-2011, 06:21 PM
Offroader239
Im new here to the forum, and hate to bring back such an old thread, but can anyone tell me, did you or do you have to relocate the new motor mounts for the bigger 4.0l from a 2.5l in a 1997 Tj?
Thanks for any advice or knowledge..
Offroader239 is offline
post #104 of 172 Old 03-05-2011, 11:10 PM
Toonces
Yes, they have to be moved. There are pictures in this thread. Really worth the read from the beginning if you're considering doing the swap.
http://www.jeepforum.com/forum/f9/2-...ml#post5475058 (pictures of the old ones being cut out and new ones being welded in)
Toonces is offline
post #105 of 172 Old 03-06-2011, 01:16 PM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Originally Posted by RnEmOvr View Post
andy i figured you of all people would have read the parts list and saw a bown dog MML
Shh you. I didn't scroll all the way back.
Nobody will mind if you resurrect an old thread for a legit reason.
I'm quite sure that they do need to be moved. Not positive, but I believe so. Might want to wait for Randy or someone else to comment.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
2.5 , 4.0 , computer , engine , harness , swap , tj , YJ
Frame Repair Underway sentinal02 YJ Wrangler Technical Forum 60 04-11-2016 12:39 AM
The swap is offically underway... leftlanetruckin YJ Wrangler Technical Forum 486 12-31-2014 07:45 PM
Phase 1 underway Schwalby TJ Wrangler Technical Forum 9 02-06-2008 09:35 AM
Swap Underway jwrangler91 YJ Wrangler Technical Forum 1 03-11-2007 08:08 PM
2.5l to 4.0l swap underway. ID89YJ YJ Wrangler Technical Forum 2 12-20-2006 08:44 PM
