2.5-4.0 swap is underway!! - Page 3 - JeepForum.com
post #31 of 172 Old 07-25-2008, 03:27 PM
gmbtj
gmbtj's Avatar
Yeah, you need to get the engine harness AND computer from a 97-99 TJ. A 2000 works, but it is for the coil rail instead of the distributor type.
Gun Metal Blue Jeep Club Member #1
Low Output 4 Cylinder Jeep Club Member #1 (President)
1999 Four Banga Wrangla - NO MORE!!!! -Going in 4.6L Stroker - TF 727 - Dana 300 HD
Teraflex 3T w/ OME's on 32" BFG M/T's
AtoZ Yaffy Style rocker guards l Tuffy Series II Security Console l Zirgo "S-Blade" electric fan l PSC Trail corners w/ LED's l Hella 500's l Expensive Sound System
gmbtj is offline
post #32 of 172 Old 07-25-2008, 04:07 PM Thread Starter
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
well crap, i guess im going shopping, so my engine will work i just need the newer harness and ECU?
RnEmOvr is offline
post #33 of 172 Old 07-25-2008, 04:34 PM
gmbtj
gmbtj's Avatar
I believe it will. I am putting in a 2000 motor as we speak. But it is necessary for me to use the 2000 harness and ECU too because of the coil change (Luckily mine came with it all). You can do the harness and ECU from the yj, but it will require splicing from hell, and there will be many things (like your gauges and other things) that wont work right because the run off you computer. Best thing to do is get a 97 to 99 harness.
By the way, I think my 4.0 might be a little more torquey, but thats because its a stroker.
gmbtj is offline
post #34 of 172 Old 07-25-2008, 04:41 PM
dodgetk81
Try Daveys Jeeps, Thats where I got all my swap stuff. I put a 99 into a 97. It was a plug and play deal.
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco
dodgetk81 is offline
post #35 of 172 Old 07-25-2008, 09:28 PM Thread Starter
RnEmOvr
RnEmOvr's Avatar
will the 97-99 harness work on the 95 motor/trans/case? splicing wires wont be an issue i can do that in my sleep, but if the TJ harness will make it more plug and play then ill go that route, Ive been w/o my jeep since June 4th, I'm ready to drive it again
RnEmOvr is offline
post #36 of 172 Old 07-29-2008, 12:49 PM Thread Starter
RnEmOvr
RnEmOvr's Avatar
does anyone have # to daveys jeep
RnEmOvr is offline
post #37 of 172 Old 07-29-2008, 02:33 PM
jeepin79
2008 KK Liberty
330-337-5037
I bought a couple things from them, they have just about everything but I think they are expensive. You may want to shop around a little bit.
jeepin79 is offline
post #38 of 172 Old 07-29-2008, 03:41 PM
dodgetk81
Originally Posted by jeepin79 View Post
330-337-5037
Some things seem expensive, some dont. I got my entire engine/tranny swap from them last year for 1200. That was wiring,computer, engine, auto trans, shifter and all cables, transfer case input shaft, and whatever else I needed. It was from a 99 with 60,000 mi. It doesn't hurt to call
post #39 of 172 Old 07-31-2008, 12:27 AM Thread Starter
RnEmOvr
RnEmOvr's Avatar
330-337-5037
thanks, noone around me has them so he has to do,
also is it just TJ comp and harness or could i use others like an XJ or ZJ
RnEmOvr is offline
post #40 of 172 Old 07-31-2008, 08:10 PM
Doctor7474
It would probably be easier to get a TJ harness and ECM. Should be plug and play that way.
I've never done a fuel injected engine swap using OEM harness's and ECM's.
Put an LSX engine into a 69 Camaro last year. Used Accel DFI and a painless wiring harness. Kinda like it better that way, since with the DFI if you change cams, add turbos/superchargers ect... you can program it yourself. But thats a totally different story then what you're doing.
Doctor7474 is offline
post #41 of 172 Old 08-03-2008, 05:52 AM
jeepsurf
Here's a link to a jeep graveyard here in nc. Give em a call and price ur harness an ecm.
http://www.easternautomotive.net/
jeepsurf endorses this post. Most of the time
1990 2.5 YJ / 1997 2.5 TJ
USAF VET
My YJ build thread
Nightcrew alive and well, now on VB 4.0
Food mailed 3ooo miles
jeepsurf is offline
post #42 of 172 Old 08-07-2008, 01:53 PM
gmbtj
gmbtj's Avatar
And most of the sensors on the yj's engine ran off 9 volts, tj's were mostly 5 volts if I remember correctly, so you might be having to replace some sending units and other sensors off the engine, transmission, etc.
gmbtj is offline
post #43 of 172 Old 08-07-2008, 04:51 PM
Tatersaladx
I just pulled the harness off of a motor i pulled from a 97 TJ, I had to cut the wire to the alternator so idk if its any good to you. I could also get the ECM, too PM me if your interested.
Tatersaladx is offline
post #44 of 172 Old 08-15-2008, 06:12 PM Thread Starter
RnEmOvr
RnEmOvr's Avatar
can i use the comp from a auto or do i need one from 5spd?
RnEmOvr is offline
post #45 of 172 Old 09-05-2008, 10:17 PM Thread Starter
RnEmOvr
RnEmOvr's Avatar
ECU and harness have been ordered, i finally got a job so things should start rolling good now
RnEmOvr is offline
2.5 , 4.0 , computer , engine , harness , swap , tj , YJ
Frame Repair Underway sentinal02 YJ Wrangler Technical Forum 60 04-11-2016 12:39 AM
The swap is offically underway... leftlanetruckin YJ Wrangler Technical Forum 486 12-31-2014 07:45 PM
Phase 1 underway Schwalby TJ Wrangler Technical Forum 9 02-06-2008 09:35 AM
Swap Underway jwrangler91 YJ Wrangler Technical Forum 1 03-11-2007 08:08 PM
2.5l to 4.0l swap underway. ID89YJ YJ Wrangler Technical Forum 2 12-20-2006 08:44 PM
