2.5-4.0 swap is underway!! - Page 11 - JeepForum.com
post #151 of 173 Old 11-21-2013, 08:15 PM
rda616
Originally Posted by Nawarsaleh3 View Post
Where can i find these after market mounts from, the dealer wants outstanding prices!!!!
Also swapping a 4.0L into my 97 Tj, still looking for the ax15 with a 23 spline 231 t-case?
The yellow aftermarket mounts in the pictures are the engine brackets and rubber mounts. Those look to be brown dog. The black ones are factory frame mounts you will need to weld on.
rda616 is offline
post #152 of 173 Old 11-22-2013, 05:02 AM
wwch99tj
http://browndogindustries.com/
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #153 of 173 Old 11-23-2013, 07:58 AM Thread Starter
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
hey guys so i been doing some research on here and everyone is telling me i should go with the 5.2 or 5.9 Dodge motor instead of swapping the 2.5L to a 4.0L......
http://www.jeepforum.com/forum/f22/9...-swap-1814738/
Having done this swap I agree, I wish I would have went V8
That yellow ones are from Brown Dog as linked above. The black ones are from the dealer and part numbers are on page two. If the price has went up you could try making your own.
Sent from my phone where grammar isn't easy.
RnEmOvr is offline
post #154 of 173 Old 04-30-2014, 03:45 PM
Jeepkid315
Im not interested in trading. sorry
-JRRJR
Jeepkid315 is offline
post #155 of 173 Old 04-30-2014, 03:51 PM Thread Starter
RnEmOvr
RnEmOvr's Avatar
Huh?
RnEmOvr is offline
post #156 of 173 Old 08-02-2014, 10:55 PM
1ofakind
I started this swap a few days ago, I got a donor 1998 jeep wrangler with the 4.0 with ax-15 and I have a 1997 with a 2.5 auto.
I have a question, can I keep my harness for my cluster and dash in my tub, and just use the 4.0 motor harness and plug it into the new ecu?
Also since my jeep had the auto transmission would I need to cut out the floor at all?
can I still use my drive shafts or should I get a new front and rear? I was going to do a sye since I had to change my input shaft anyways. I have a new front I can use from a friend but needs all new u joints.
awesome write up I read the whole thing a couple days ago to help me get started now my 2.5 motor will be out tomorrow evening! so pumped!
1ofakind is offline
post #157 of 173 Old 08-03-2014, 11:26 AM Thread Starter
RnEmOvr
RnEmOvr's Avatar
You do not need to swap the tub harness, only the engine harness.
I don't think you would need to cut for the tub.
Are you swapping transmissions or keeping your auto?
As for shafts you may be able to keep the old ones. I did few mods with my swap that required a new shaft.
RnEmOvr is offline
post #158 of 173 Old 08-03-2014, 12:57 PM
1ofakind
Nope I'm using the ax-15 from the donor and swapping the input shafts since the tcase he is giving me doesn't have 4hi. Awesome so I'll leave my 2.5 harness with it.
I see you didn't use your factory belly pan, will I have any issues if I use my factory 2.5 belly pan (incase I don't get the 4.0 pan) with the new tranny with the lineup of the tcase and rear diff?
1ofakind is offline
post #159 of 173 Old 08-03-2014, 11:06 PM
bigfootdave
Just a few comments from my 97 swap:
The difference in motor mount location is about 5.5" farther forward, if you use the existing center pan as the point to start your locating. Doing so causes about a 1.5" too long rear drive shaft when using a NV3550 on std mount. I believe the AX-15 is the same. I soft bolted everything together from T/C forward to locate the motor mounts.
If you replace the input shaft on the T/C, you may have a howler.....I did. I also had an alignment problem with the linkage and went to the Novak cable shifter....best decision made in this swap.
The front drive shaft was okay on mine, but I have a HP D30. I also have zero lift over stock.
As was stated before, all you need to replace is the engine wiring harness and PCM. Plug and play as it's said.
You may experience a nose down attitude from the extra weight up front. I did, and went to 6 cyl front springs. No further issues.
Even most of the exhaust system is the same...easy deal.
Holler if you have any questions
bigfootdave is offline
post #160 of 173 Old 08-04-2014, 12:25 PM
1ofakind
Awesome!! its great having guys on this site having done this swap hands on, I have a complete drive line from a 98 with the ax15, ill be putting in so depends if he includes the drive shafts and belly pan, I mean he is leaving it on a frame with a tub and some misc other stuff I requested so a guy can only assume.. right?
So if that's the case and I get the whole shebang then its just a simple swap from one frame to another I guess
So as far as the motor mounts go should I just take an angle grinder and make a nice clean cut? then weld in the new mounts? can I use the factory mounts from my donor? I don't have access to a plasma cutter or a torch...
1ofakind is offline
post #161 of 173 Old 08-04-2014, 09:34 PM
1ofakind
one question for you, will I have to move my steering shaft bracket??
1ofakind is offline
post #162 of 173 Old 08-05-2014, 09:59 AM
bigfootdave
Yes, the steering support bracket also moves for clearance issues. You can use your donor for location.
Regarding motor mounts, the 4.0 mounts are two pieces each side, basically a stiffening liner inside the outer shell. I cut mine off a donor frame, I actually cut into the frame, cleaned and dressed them well and rewelded them into place. I did not have a plasma cutter but wished I did. I understand new mounts can be bought from a couple sources including the Jeep dealer. I used what I had with no issues.
post #163 of 173 Old 08-05-2014, 07:30 PM
1ofakind
did you also use a grinder? or how did you cut it? thanks im really excited to get this motor in, I have a 4 day weekend from work so I plan to have it all put in and hopefully running this weekend!
1ofakind is offline
post #164 of 173 Old 08-08-2014, 09:47 AM Thread Starter
RnEmOvr
RnEmOvr's Avatar
I just trimmed old 4cyl mounts (didn't even clean them from frame), I purchashed 6cyl mounts from dealer. Part numbers are on page 2
RnEmOvr is offline
post #165 of 173 Old 08-08-2014, 09:34 PM
bigfootdave
I used a grinder to cut them off and grind down the area to clean up the appearance. A good cutting wheel will slice right through, and then use a good flat wheel for the clean up.
2.5 , 4.0 , computer , engine , harness , swap , tj , YJ
Frame Repair Underway sentinal02 YJ Wrangler Technical Forum 60 04-11-2016 12:39 AM
The swap is offically underway... leftlanetruckin YJ Wrangler Technical Forum 486 12-31-2014 07:45 PM
Phase 1 underway Schwalby TJ Wrangler Technical Forum 9 02-06-2008 09:35 AM
Swap Underway jwrangler91 YJ Wrangler Technical Forum 1 03-11-2007 08:08 PM
2.5l to 4.0l swap underway. ID89YJ YJ Wrangler Technical Forum 2 12-20-2006 08:44 PM
