2.5-4.0 swap is underway!! - Page 10 - JeepForum.com
post #136 of 173 Old 10-07-2013, 10:57 PM
Dirty_Bird
pcm from a 4.0l TJ 1999 i think
Dirty_Bird is offline
post #137 of 173 Old 10-07-2013, 11:00 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Is the wiring harness compatible in your TJ with that PCM?
Again, fill in your profile...
Knuckelhead is offline
post #138 of 173 Old 10-07-2013, 11:36 PM
Dirty_Bird
yes the wiring is compatible from what i know. i just added 2 injector wires.. im doing the wiring this week to finish it. I did fill up some of my profile. thanks
post #139 of 173 Old 10-10-2013, 01:59 PM Thread Starter
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Funny thing is the PCM plug stayed the same through out the years. What changed was where the engine harness connects to the firewall harness.
So you are using the 4 cyl harness and adding 2 new injector lines? Did you run them back to the PCM or just tap into different injector?
Sent from my phone where grammar isn't easy.
RnEmOvr is offline
post #140 of 173 Old 10-14-2013, 02:45 AM
Dirty_Bird
Hey there guys.. sorry for the hold up..
2 weekends and the swap is done!
The only issues I have encountered is the power steering cables and the rad hoses. not a big deal.. im going to go get some fitted.
And then there is the instrument cluster.
engine and all the other parts are from a 99 cherokee.
didnt swap the cluster.. and the pcm is sending the info when i do the test.
so turn the ignition on , lights turn on like seat belt.. park break.. and so on.. all normal. except the batt gage and fuel gage does not go to where its supposed to be (good battery)
No I turn over the key.. all dials goes all the way . .and then comes back to 0 and the gauges don't work where they are supposed to be.. all lights up and all but oil pressure , gas, speed, and batt gauges does not move.
Any suggestions?
I was thinking the ground wires but it would not work at all.. doing the tests for the gauges and all works in sequence..
weird lol
Hey but the engine starts and runs like a dream.. might be straight pipe for a little bit lol
post #141 of 173 Old 10-15-2013, 08:55 PM Thread Starter
RnEmOvr
RnEmOvr's Avatar
PCM isn't sending proper signal to dash.
RnEmOvr is offline
post #142 of 173 Old 10-20-2013, 10:20 PM
Dirty_Bird
Would you know if flashing the pcm to make it work for the 2001 cluster would work?
post #143 of 173 Old 10-21-2013, 07:50 AM Thread Starter
RnEmOvr
RnEmOvr's Avatar
It might. There are a few places online that can do it for you. I would call them and ask.
RnEmOvr is offline
post #144 of 173 Old 11-02-2013, 01:23 PM
Dirty_Bird
lol ok I got a cluster from a 97 tj and spliced and redid the wiring and had to add a wire into c28 of the pcm to make it work.. all is great now!
post #145 of 173 Old 11-13-2013, 04:46 PM
Nawarsaleh3
Also swapping 2.5L for a 4.oL
i also am replacing my 97 2.5l to a 4.0l, i was wondering why i would need aftermarket mounts? I know i need a Ax-15( which i cant find! ) but can i still use the stock transfer case and shafts that came with my 2.5l?
Thanks you for the detailed info!
Nawarsaleh3 is offline
post #146 of 173 Old 11-13-2013, 04:50 PM
wwch99tj
No the 2.5's transfer case has a 21 spline input and the 4.0's has 23... not sure about the driveshafts.
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #147 of 173 Old 11-13-2013, 05:39 PM
rda616
Because the 4 and 6 cylinder frame mounts are different. You can use your transfer case, but you need to change the input shaft to do so.
rda616 is offline
post #148 of 173 Old 11-21-2013, 07:51 PM
Nawarsaleh3
hey guys so i been doing some research on here and everyone is telling me i should go with the 5.2 or 5.9 Dodge motor instead of swapping the 2.5L to a 4.0L......
http://www.jeepforum.com/forum/f22/9...-swap-1814738/
post #149 of 173 Old 11-21-2013, 08:07 PM
rda616
Maybe I'm biased, but I agree.
rda616 is offline
post #150 of 173 Old 11-21-2013, 08:08 PM
Nawarsaleh3
new motor mounts came in thanks brown dog, also picked up my factory frame mounts
Where can i find these after market mounts from, the dealer wants outstanding prices!!!!
Also swapping a 4.0L into my 97 Tj, still looking for the ax15 with a 23 spline 231 t-case?
2.5 , 4.0 , computer , engine , harness , swap , tj , YJ
Frame Repair Underway sentinal02 YJ Wrangler Technical Forum 60 04-11-2016 12:39 AM
The swap is offically underway... leftlanetruckin YJ Wrangler Technical Forum 486 12-31-2014 07:45 PM
Phase 1 underway Schwalby TJ Wrangler Technical Forum 9 02-06-2008 09:35 AM
Swap Underway jwrangler91 YJ Wrangler Technical Forum 1 03-11-2007 08:08 PM
2.5l to 4.0l swap underway. ID89YJ YJ Wrangler Technical Forum 2 12-20-2006 08:44 PM
